MaxConnections
Started by Fredrick Ughimi, August 16, 2018, 12:07:50 PM
Fredrick Ughimi
Hello,
Has anyone used the MaxConnections in the SqliteningServer settings to a good effect. I assume the MaxConnections is equal to total number of systems on the network including the server using the application.
I have this scenario:
1. Total Computers on the network (including the server) = 5
2. MaxConnections=5
3. Actual Connections = 4 (I get maximum connection exceeded error) *
*I noticed that if there are just 4 computers connected and using the application. I get maximum connection exceeded error.
Note: I made sure no multiple instances of the application is allowed to run on a system.
Has anyone experience this before?
Best regards,
#1
Fredrick, is SQLitening logging connections to the SQLientingServer.LOG file?  Have you inspected it to verify what connections are being logged?  Is it possible that your application is opening more than one connection (ie. in a threaded function)?
#2
You might also look at List all Active Connections using SQLiteningServerAdmin.exe to see what is connected.
I increased MaxConnections in SQLiteningServer.Cfg while applications are running and
clicked Refresh the data and FACT using SQLiteningServerAdmin.exe.  It works as expected with multiple stations.
if you can't find the error, I would guess MaxMaxConnections in SQLiteningServer.Cfg got changed
and the FACT was not refreshed.  I bet it works, now?
#3
Like Bern has said, the log should show what happened.
Tools:
List all Active Connections will show connections even if they will not be active for about 4-minutes then they will go way.
SQliteningServer.Cfg set to MaxConnections = 5
SQLiteningServer.log
08-20-2018 13:30:12 Conn #70 SK 620 CJSQLitening192.168.0.2 (192.168.0.2 on port 50130)
08-20-2018 13:30:15 Conn #71 SK 620 CJSQLitening192.168.0.2 (192.168.0.2 on port 50131)
08-20-2018 13:30:18 Conn #72 SK 620 CJSQLitening192.168.0.2 (192.168.0.2 on port 50133)
08-20-2018 13:30:20 Conn #73 SK 620 CJSQLitening192.168.0.2 (192.168.0.2 on port 50134)
08-20-2018 13:30:23 Conn #74 SK 620 CJSQLitening192.168.0.2 (192.168.0.2 on port 50135)
08-20-2018 13:30:28 Conn #75 SK 620 CJSQLitening192.168.0.2 (192.168.0.2 on port 50136)
08-20-2018 13:30:29 Conn #76 SK 620 CJSQLitening192.168.0.2 (192.168.0.2 on port 50137)
08-20-2018 13:30:31 Conn #77 SK 620 CJSQLitening192.168.0.2 (192.168.0.2 on port 50138)
08-20-2018 13:30:52 Conn #78 SK 620 CJSQLitening192.168.0.2 (192.168.0.2 on port 50142)
08-20-2018 13:30:55 Conn #79 SK 620 CJSQLitening192.168.0.2 (192.168.0.2 on port 50144)
08-20-2018 13:34:23 Dcon #75 WentAway
08-20-2018 13:34:23 Dcon #76 WentAway
08-20-2018 13:34:26 Dcon #77 WentAway
08-20-2018 13:34:47 Dcon #78 WentAway
08-20-2018 13:34:49 Dcon #79 WentAway
Fredrick Ughimi
Hi CJ,
I would take a closer look at the log to see what is going on.
Hello Bern,
...Is it possible that your application is opening more than one connection (ie. in a threaded function)?
No. Like I mentioned in my earlier post, I made sure that doesn't happen.
Fredrick Ughimi
No. Just one line and the value was 7.
