May 18, 2021, 06:41:33 PM
Audit Trail
Started by Fredrick Ughimi, September 11, 2018, 02:51:33 PM
Fredrick Ughimi
Hello,
Has anyone done Audit Trail using SQLitening? I searched but I did see anything of that sort here.
Writing SQLite Triggers would do?
Yeah, I created a system that allows me to log every SQL statement being executed in a transaction table.  See here:
https://www.sqlitening.planetsquires.com/index.php?topic=3539.msg18054;topicseen#msg18054
September 13, 2018, 01:10:12 PM #2 Last Edit: September 13, 2018, 10:44:01 PM by cj
Didn't like previous version.
This version also captures error messages into log and doesn't need any other functions
#INCLUDE "sqlitening.inc"
$E1 = "...................................................." + $CR
$E2 = "...................................................." + $CR
FUNCTION PBMAIN () AS LONG  'errorlog.bas 9/13/18 CJ
LOCAL sql AS STRING
slSetProcessMods "E1"  'any error will be in the log
KILL "junk.db3":ERRCLEAR
slopen "junk.db3","C"
sql = "create table if not exists trantable(statement)" :slexe sql:logit(sql)
sql = "select * from trantable"                         :slsel sql:logit(sql)
sql = "drop table if exists HeidiKlum"                  :slexe sql:logit(sql)
sql = "create table wrong"                              :slexe sql:logit(sql)
sql = "drop table if exists Table1"                     :slexe sql:logit(sql)
sql = "select rowid      from trantable"                :slsel sql:logit(sql)
sql = "select statement  from trantable"                :slsel sql:logit(sql)
sql = "JIBBERISH"                                       :slexe sql:logit(sql)
sql = "select * from xyz"                               :slsel sql:logit(sql)
sql = "select 'Have'||' a'||' good'||' day'"            :slsel sql:logit(sql)
viewall
SUB ViewAll
LOCAL sArray() AS STRING
IF slSelAry("select statement from trantable",sArray(),"Q9E0") THEN
   ? slGetError,%MB_SYSTEMMODAL,"Viewer"
ELSEIF UBOUND(sArray) < 1 THEN
  ? "No data",%MB_SYSTEMMODAL,"Viewer"
  ? JOIN$(sArray(),$CR),%MB_SYSTEMMODAL,"Viewer"
FUNCTION LogIt(s AS STRING) THREADSAFE AS LONG
LOCAL sHeader AS STRING  'returns 1 on success
LOCAL AnError AS LONG
AnError = slGetErrorNumber 'set flag
IF AnError THEN 'experimental, show last error in log
  slexebind "insert into trantable values(?)",slBuildBindDat($E1 + slGetError,"T"),"E0"
sHeader = LEFT$(DATE$,5) + " " + TIME$ + " " + s
slexebind "insert into trantable values(?)",slBuildBindDat(sHeader,"T"),"E0"
IF slGetErrorNumber THEN
   ? slGetError + $CR + $CR + s,%MB_SYSTEMMODAL,"LogIt"
IF AnError THEN slexebind "insert into trantable values(?)",slBuildBindDat($E2,"T"),"E0"
IF slGetChangeCount <> 1 THEN
   ? "Write to log failed",%MB_SYSTEMMODAL,"LogIt"
Fredrick Ughimi
Thanks Bern and CJ for your response.
I wanted to create an audit trail that would track users actions like: Save, Update and Delete on a table.
Earlier on I was having issues replying to posts here. It's all good now.
Screenshot showing logging of all SQL statements and any errors.
Fredrick Ughimi
Hello CJ,
I was trying to wrap my head around your sample code. I get it now. All I need to do is substitute the SQL statement with my Save, Update and Delete routines. Thanks.
September 14, 2018, 11:34:20 AM #6 Last Edit: September 14, 2018, 11:49:55 AM by cj
If the SQL statements don't use binding.
If binding is used wiill take some thought.
%KillDatabase=1
SUB LogIt(sql AS STRING)
slexebind "insert into log values(?)",slBuildBindDat(sql,"T")
FUNCTION PBMAIN () AS LONG  'errorlog2.bas 9/14/18
IF %KillDatabase THEN KILL "junk.db3":ERRCLEAR
LOCAL sql AS STRING
slexe "create table if not exists log(statements)"
slexe "create table if not exists t1(First,Last)"
sql = "Insert into T1 values('John','Doe')"                :slexe sql:Logit sql
sql = "Update t1 set First = 'Fredrick' where Last = 'Doe'":slexe sql:logit sql
sql = "Delete from t1 where Last = 'Doe'"                  :slexe sql:Logit sql
? GetData("select * from LOG"),,"Log"
FUNCTION GetData(sql AS STRING) AS STRING
IF slSelAry(sql,sArray(),"Q9E0c") THEN
  ? slGetError,%MB_ICONERROR,FUNCNAME$
  ? sql + $CR + "No data",%MB_SYSTEMMODAL,FUNCNAME$
  FUNCTION = JOIN$(sArray(),$CR)
September 14, 2018, 01:00:32 PM #7 Last Edit: September 14, 2018, 01:14:56 PM by cj
In a real application, processing errors is required so this design might be more practical.
Other statements that might be important to log are  "create", "drop", "begin", "end"  and others?
Logging errors should be considered for security.
I removed the slGetChangeCount check because some statements like "begin" don't modify, but might be needed to see what is happening.
Again, this does not log statements using  binding like:  slexebind "insert into t1 values(?,,?,?) ",slBuildBindDat(sql,"T")
%KillDatabase=1
slexebind "insert into log values(?)",slBuildBindDat(sql,"T"),"E0"
FUNCTION PBMAIN () AS LONG  'errorlog2.bas 9/13/18 CJ
LOCAL result AS LONG
LOCAL sql    AS STRING
sql    = "drop table if exists t1"
result = slExecute(sql)
sql    = "create table if not exists t1(First,Last)"
sql    = "Insert into t1 values('John','Doe')
sql    = "Update t999 set First = 'Fredrick' where Last = 'Doe'"
sql    = "Delete from t1 where First = 'Fredrick'"
sql    = "Insert into t1 values('Heidi','Klum')
? "Log" + $CR + GetData("select * from log") + $CR + $CR +_
   "t1"  + $CR + GetData("select * from t1")
FUNCTION slExecute(sql AS STRING) AS LONG
  slexe(sql,"E0")
  logit sql
Fredrick Ughimi
September 14, 2018, 09:13:50 PM #9 Last Edit: September 18, 2018, 02:49:08 AM by cj
Writing any text to a SQLite column is easy even if the data has embedded quotes.
slExeBind "Insert into Table1 values(?)",slBuildBindDat(Text$,"T")
This enables logging any statements you want and disallowing statements that fail or didn't modify the table.
Statements that fail or didn't modify the log could be placed into another log.
FUNCTION PBMAIN () AS LONG  'errorlog3.bas 9/14/18 CJ
slexe "drop table if exists log"
slExecute "create table if not exists t1(First,Last)"
slExecute "Insert into t1 values('one','one')"
slExecute "Insert into t1 values('two','two')"
slExecute "Insert into t1 values('three','three')"
slExecute "Insert into t1 values('four','four')"
slExecute "Update T1 Set First = 'Heidi'"
slExecute "Update T1 Set Last  = 'Klum'"
slExecute "Delete from t1 where rowid > 2"
  ? "Log" + $CR + GetData("select * from log") + $CR + $CR +   "Data File"  + $CR + GetData("select rowid,* from t1")
LOCAL ChangeCount AS LONG
ChangeCount = slGetChangeCount("T") 'system change count
IF slexe(sql,"E0") THEN      'invalid statement, do something different with it
   FUNCTION = slGetErrorNumber
   ? slGetError+ $CR + sql,,"Statement Failed Log Not Updated"
ChangeCount = slGetChangeCount("T") - ChangeCount
LOCAL s AS STRING
s = LEFT$(LTRIM$(LCASE$(sql)),7) 'get rid of leading spaces, lower case
SELECT CASE s
  CASE "insert ":? sql,,USING$("INSERT changes #",changecount)
  CASE "update ":? sql,,USING$("UPDATE changes #",changecount)
  CASE "delete ":? sql,,USING$("DELETE changes #",changecount)
  CASE ELSE     :? sql,,USING$("Other changes  #",ChangeCount)
'decide what to log
IF ChangeCount > 0 THEN  'modify to taste
ELSEIF UBOUND(sArray)>0 THEN
LOCAL s AS STRING
SELECT CASE s
'decide what to log
