February 27, 2021, 12:27:14 PM
Audit trail and slInsert (Version 2)
Started by cj, September 12, 2018, 06:56:32 PM
September 12, 2018, 06:56:32 PM Last Edit: September 13, 2018, 01:31:04 PM by cj
'Encapsulated 3 functions to include logging
'slSel    ----> slSe
'slExe    ----> slEx
'slSelAry ----> slSelAr
'slInsert added for simple text inserting
#INCLUDE "sqlitening.inc"
FUNCTION PBMAIN () AS LONG 'BindAndLog.Bas  9/12/18 CJ
LOCAL sTemp() AS STRING
REDIM sCol(1 TO 2) AS STRING 'columns in table
KILL   "junk.db3":ERRCLEAR
slOpen "junk.db3","C"
slexe  "create table if not exists trantable(statements)"
slex   "create table if not exists t1(c1,c2)"
'slInsert - insert data without quoting strings
sCol(1)="c1 binding"
sCol(2)="c2 binding"
slInsert "t1",sCol() 'tablename$,datacols$()
slex     "insert into t1 values('c1 no bind','c2 no bind')"
slse     "select sqlite_version()",0,"E0":slGetRow':? slf(1),,"SQLite Version"
slex     "drop table if exists FimTable1234"
slSelAr "select rowid,* from t1",sTemp(),"Q9"
? "T1 Table" + $CR + JOIN$(sTemp(),$CR) + $CR + $CR + "Log" + $CR +_
Viewer("select rowid,* from trantable" ,"Q9"),,"Both tables"
FUNCTION slInsert(sTable AS STRING,sCol() AS STRING) AS STRING
LOCAL x AS LONG, sInsert,sBind,sQuestionMarks,sLog AS STRING
FOR x = 1 TO UBOUND(sCol)
  sBind+=slBuildBindDat(sCol(x),"T")
sQuestionMarks = LEFT$("(" + REPEAT$(UBOUND(sCol),"?,"),-1) + ")"  '(?,?,?)
slexeBind "Insert into " + sTable + " values " + sQuestionMarks,sBind
IF slGetChangeCount = 0 THEN ? "Insert error",%MB_SYSTEMMODAL,"slInsert"
sLog = LEFT$(DATE$,5) + " " + TIME$ + " " + "Insert into " + sTable + " values (" + JOIN$(sCol(),",") + ")"
slexebind "insert into trantable values(?)",slBuildBindDat(sLog,"T")
FUNCTION Viewer(sql AS STRING,sModChars AS STRING) AS STRING
LOCAL sArray() AS STRING
FUNCTION = slSelAr(sql,sArray(),sModChars)
'(BYREF rsStatement AS STRING, BYREF wsaColsAndRows() AS STRING, OPTIONAL BYVAL rsModChars AS STRING) AS LONG
FUNCTION slSelAr(rsStatement AS STRING, wsaColsAndRows() AS STRING,OPT rsModChars AS STRING) AS STRING
LOCAL rsModChars2 AS STRING
LOCAL sLog AS STRING
LOCAL wsaColsAndRows() AS STRING
IF ISFALSE(ISMISSING(rsModChars)) THEN rsModChars2 = rsModChars
slSelAry rsStatement,wsaColsAndRows(),rsModChars2
FUNCTION = JOIN$(wsaColsAndRows(),$CR)
sLog = LEFT$(DATE$,5) + " " + TIME$ + " " + rsStatement
'BYREF rsStatement AS STRING, OPTIONAL BYVAL rsModChars AS STRING) AS LONG
FUNCTION slex(sql AS STRING,OPT rsModChars AS STRING) AS LONG
slexe sql,rsModChars2
sLog = LEFT$(DATE$,5) + " " + TIME$ + " " + sql
'(BYREF rsStatement AS STRING, OPTIONAL BYVAL rlSetNumber AS LONG, OPTIONAL BYVAL rsModChars AS STRING) AS LONG
FUNCTION slse(rsStatement AS STRING,OPT rlSetNumber AS LONG,rsModChars AS STRING) AS LONG
LOCAL rlSetNumber2 AS LONG
LOCAL sLog,rsModChars2  AS STRING
IF ISFALSE(ISMISSING(rlSetNumber)) THEN rlSetNumber2= rlSetNumber
slSel rsStatement ,rlSetNumber2,rsModChars2
Didn't like previous version.
This version captures errors in log and doesn't need any other functions
$E1 = "...................................................." + $CR
$E2 = "...................................................." + $CR
FUNCTION PBMAIN () AS LONG  'errorlog.bas 9/13/18 CJ
LOCAL sql AS STRING
slSetProcessMods "E1"  'any error is captured into the log
slopen "junk.db3","C"
sql = "create table if not exists trantable(statement)" :slexe sql:logit(sql)
sql = "select * from trantable"                         :slsel sql:logit(sql)
sql = "drop table if exists HeidiKlum"                  :slexe sql:logit(sql)
sql = "create table wrong"                              :slexe sql:logit(sql)
sql = "drop table if exists Table1"                     :slexe sql:logit(sql)
sql = "select rowid      from trantable"                :slsel sql:logit(sql)
sql = "select statement  from trantable"                :slsel sql:logit(sql)
sql = "JIBBERISH"                                       :slexe sql:logit(sql)
sql = "select * from xyz"                               :slsel sql:logit(sql)
sql = "select 'Have'||' a'||' good'||' day'"            :slsel sql:logit(sql)
viewall
SUB ViewAll
IF slSelAry("select statement from trantable",sArray(),"Q9E0") THEN
   ? slGetError,%MB_SYSTEMMODAL,"Viewer"
ELSEIF UBOUND(sArray) < 1 THEN
  ? "No data",%MB_SYSTEMMODAL,"Viewer"
  ? JOIN$(sArray(),$CR),%MB_SYSTEMMODAL,"Viewer"
FUNCTION LogIt(s AS STRING) THREADSAFE AS LONG
LOCAL sHeader AS STRING  'returns 1 on success
LOCAL AnError AS LONG
AnError = slGetErrorNumber 'set flag
IF AnError THEN 'experimental, show last error in log
  slexebind "insert into trantable values(?)",slBuildBindDat($E1 + slGetError,"T"),"E0"
sHeader = LEFT$(DATE$,5) + " " + TIME$ + " " + s
slexebind "insert into trantable values(?)",slBuildBindDat(s,"T"),"E0"
IF slGetErrorNumber THEN
   ? slGetError + $CR + $CR + s,%MB_SYSTEMMODAL,"LogIt"
IF AnError THEN slexebind "insert into trantable values(?)",slBuildBindDat($E2,"T"),"E0"
IF slGetChangeCount <> 1 THEN
   ? "Write to log failed",%MB_SYSTEMMODAL,"LogIt"
LOCAL sql AS STRING
slSetProcessMods "E1"  '[b]any error will be in the log [/b]
viewall
SUB ViewAll
slexebind "insert into trantable values(?)",slBuildBindDat(sHeader,"T"),"E0"
