February 16, 2020, 11:59:02 pm
SQLitening & RMChart
Started by Fredrick Ughimi, October 30, 2018, 07:09:24 am
Fredrick Ughimi
Hello Everyone,
Has anyone here worked with SQLitening & RMChart?
I am currently looking to the possibility of creating charts from SQLitening Data.
Fim
RMchart is an excellent product, but .....
It's dead, no further development, wondering if the product's author is still alive.
/Fim
Fim W
Fredrick Ughimi
Hello Fim,
RMChart is here and still being actively used other by programming platforms like XBase++
http://www.brothersoft.com/rmchart-35638.html
Fredrick Ughimi
Hello Everyone,
I think RMChart is pretty straight forward. Its just reading the values from SQLitening as double array that is where I am stuck.
From RMChart sample: '****** Read data values ******
REDIM aData(0) AS DOUBLE
REDIM aData(4)
aData(0) = 30 : aData(1) = 40 : aData(2) = 70 : aData(3) = 60 : aData(4) = 20
How do I translate the above, reading from SQLitening table? I have tried using slSelAry, it uses string array, but RMChart requires double array. I really stuck and I need some help.
Thank you in advance.
Fredrick Ughimi
This is verbose, limiting and not flexible, but it works.
    REDIM aData(4)
    LOCAL dTemperature1 AS DOUBLE
    LOCAL dTemperature2 AS DOUBLE
    LOCAL dTemperature3 AS DOUBLE
    LOCAL dTemperature4 AS DOUBLE
    LOCAL dTemperature5 AS DOUBLE
    slSEL "SELECT Temperature as ITemperature1 FROM tblObservationChart LIMIT 1"
    IF ISTRUE slGetRow() THEN
       dTemperature1 = VAL(slFN("ITemperature1"))
    slCloseSet
    slSEL "SELECT Temperature as ITemperature2 FROM tblObservationChart LIMIT 2, 1"
       dTemperature2 = VAL(slFN("ITemperature2"))
    slCloseSet
    slSEL "SELECT Temperature as ITemperature3 FROM tblObservationChart LIMIT 3, 1"
       dTemperature3 = VAL(slFN("ITemperature3"))
    slCloseSet
    slSEL "SELECT Temperature as ITemperature4 FROM tblObservationChart LIMIT 4, 1"
       dTemperature4 = VAL(slFN("ITemperature4"))
    slCloseSet
    slSEL "SELECT Temperature as ITemperature5 FROM tblObservationChart LIMIT 5, 1"
       dTemperature5 = VAL(slFN("ITemperature5"))
    slCloseSet
    aData(0) = dTemperature1 : aData(1) = dTemperature2 : aData(2) = dTemperature3 : aData(3) = dTemperature4 : aData(4) = dTemperature5
Any better suggestions would be appreciated.
Best regards.
November 04, 2018, 10:39:12 pm #5 Last Edit: November 05, 2018, 10:45:22 am by cj
#INCLUDE "sqlitening.inc"
FUNCTION PBMAIN () AS LONG
LOCAL x,elements AS LONG
slOpen "junk.db3","C"
slexe "drop table if exists table1
slexe "create table if not exists table1(temperature integer)"
slexe "insert into table1(temperature)values(30),(40),(70),(60),(20),(17),(88)"
REDIM sArray(0) AS STRING
slSelAry "select temperature from table1",sArray(),"Q9"
'read each value into the aData array subscript.
elements = UBOUND(sArray)
IF elements > 0 THEN
  REDIM aData(elements) AS DOUBLE
  FOR x = 1 TO elements
   aData(x-1) = VAL(sArray(x))
Fredrick Ughimi
Hello CJ,
Excellent. Thanks for the sample code. The problem is how do I individually read each values into the
aData array subscripts.
aData(0) = ? : aData(1) = ? : aData(2) = ? : aData(3) = ? : aData(4) = ?
Best regards.
The code did this so don't understand the question?
aData(0) = row 1 temperature as a DOUBLE
aData(1) = row 2 temperature as a DOUBLE
aData(2) = row 3 temperature as a DOUBLE
aData(3) = row 4 temperature as a DOUBLE
aData(4) = row 5 temperature as a DOUBLE
slSelAry "select temperature from table1 LIMIT 5",sArray(),"Q9"
  aData(x-1) = VAL(sArray(x)) read each value into the aData array subscript.
Fredrick Ughimi
Yes. I understand the values are read into aData array.
Just that the values in my table doesn't reflect what the Chart says. Maybe I am doing something wrong. I would check.
Thanks a lot.
Fredrick Ughimi
Hello CJ,
I mistakenly was changing the values of the same Database in another directory. My mistake.
Works great! Thanks once again.
