September 16, 2021, 11:06:43 PM
Can not start the server
Started by Fim, December 04, 2018, 02:05:54 PM
Fim
All I've done is to change sqlite3.dll from versions 3.14 to 3.26. Then I get wrong. There is nothing in the log file.
Fim W
December 04, 2018, 03:18:42 PM #1 Last Edit: December 04, 2018, 03:25:49 PM by cj
1) See if your shortcut has "Run as administrator checked
2) If not that, then "Allow an app  through Windows Firewall"
3) If neither of these then "IPCONFIG" at command prompt and see if IP address is different in sqliteningserver.cfg
Fim
December 05, 2018, 05:21:40 AM #2 Last Edit: December 05, 2018, 05:39:55 AM by Fim
Cj,
With version 3.14, everything works as it should.
But with version 3.26 I get the error.
So I have had to switch back to version3.14, and then it works. Strange.
I was wrong, the version that works as i should is 3.7.13
/Fim W
Fim W
Fim
cj,
Many thanks.
Now it works as it should with 32 bit version.
The error was that I had downloaded the 64 bit version.
/Fim W
Fim W
