Returning Selected Columns Only In slSelAry
Started by Fredrick Ughimi, May 28, 2019, 08:01:48 PM
Fredrick Ughimi
Hello,
With the following slSelAry statement:
slSelAry "Select AccountName, AccountType, Date, SUM(Debit) as DebitSUM From tblJournalEntry " & _
 "WHERE Date BETWEEN '" + SQLiteDate(sFrom) + "' AND '" + SQLiteDate(sTo) + "' AND AccountType = 'Assets' GROUP BY AccountName", rsAssets(),"Q9c"
How do I return only AccountName and DebitSUM columns?
Kind regards.
Fredrick Ughimi
Hello CJ,
Thank you for your suggestions. Its seems option 3 is the only feasible one for me. But I get the name of the columns instead of the records. And also fixing into my code another 'wahala'.
Here is where I want to put it:
#COMPILE EXE
#DIM ALL
#INCLUDE "sqlitening.inc"
#INCLUDE "ddoc_p32.inc"
'DDOC
'  Needed Color Constants (Vb compatible)
%vbBlack = &H0&
%vbRed = &HFF&
%vbGreen = &HFF00&
%vbYellow = &HFFFF&
%vbBlue = &HFF0000
%vbMagenta = &HFF00FF
%vbCyan = &HFFFF00
%vbWhite = &HFFFFFF
%vbGrey = &HC0C0C0
%LIGHT_SHADE = &HE0E0E0
GLOBAL gName AS STRING
GLOBAL gAddress AS STRING
FUNCTION SQLiteDate(sDate AS STRING) AS STRING
     'From dd-MM-yyyy To yyyy-MM-dd
     FUNCTION = MID$(sDate,7,4) & "-" & MID$(sDate,4,2) & "-" & MID$(sDate,1,2)
FUNCTION PBMAIN () AS LONG
  'LOCAL rs() AS STRING
  LOCAL PageHeightMaximum AS SINGLE
  LOCAL iHandle,TheBin,TheStyle,DefaultZoom,NoDialog,x,EndCode,pagenum,fontsize,fontstyle,defaultcolor AS LONG
  LOCAL OutputFile AS ASCIIZ * 64
  LOCAL DocTitle AS ASCIIZ * 64
  LOCAL height,lineheight,LeftMargin,topmargin AS SINGLE
  LOCAL DefaultFont AS ASCIIZ * 64
  LOCAL rsAssets() AS STRING
  LOCAL sFrom, sTo AS STRING
  LOCAL AssetsHeight AS SINGLE
  LOCAL szAssets AS ASCIIZ * 300
  sFrom = "28-04-2019"
  sTo = "29-05-2019"
  slOpen "meganetERPDB.db3","C"
  'Assets
  IF UBOUND(rsAssets) < 1 THEN ? "No data",,EXE.NAME$:EXIT FUNCTION
  '? Join$(rs(),$CRLF),,"Data in array"
  PageHeightMaximum = 10.1  'inches
  'DefaultZoom = %DDOC_ZOOM100
  'DefaultZoom = %DDOC_ZOOM75
  defaultzoom = %DDOC_ZOOMFIT
  defaultFont = "Courier New"
  TheStyle = %ddoc_Portrait
  fontsize = 8
  TheBin = %DDOC_Bin_Auto '7
  topmargin= 2.6
  lineheight = .1666 '1/6  'each line height
  'outputfile ="cj.ddc"  'if multiuser would need unique names
  doctitle = "Mega-Net ERP - General Ledger Summary Report"
  'NoDialog = 1 'print direct with no dialog
  IF NoDialog THEN
    endCode = %DDOC_END_PRINT + %DDOC_END_DELETE
    DefaultZoom+= %DDOC_VIEWBUILD 'so no dialog will appear
    endCode = %DDOC_END_VIEW + %DDOC_END_DELETE
  'outputfile = "MyFile.DDC" 'optionally name .DDC files and delete when done
  LeftMargin = 0.5
  height = topmargin
  AssetsHeight = 7.0
  ihandle = dpStartDoc(0,_
                       DocTitle, _
                       outputfile,_
                       %DDOC_INCH,_
                       %DDOC_PAPER_LETTER,_
                       %DDOC_SYSTEM_DEFAULT, _
                       TheBin,_
                       DefaultZoom& + %DDOC_VIEWBUILD)
  IF ihandle < 1 THEN
    SELECT CASE ihandle
      CASE %DDOC_NOHANDLES  : ? "no file handles",,"dpStartDoc"
      CASE %DDOC_BADFILE    : ? "bad file name",,  "dpStartDoc"
      CASE %DDOC_FILEEXISTS
        ?  outputfile + " already exists so will delete document",,"dpStartDoc"
        KILL outputfile
        IF ERR THEN ? "Could not delete file",,EXE.NAME$
      CASE ELSE:      ?  "Error code" + STR$(iHandle),,"dpStartDoc"
  'if you let ddoc create the outputfile and need its name
  'dpGetFileName iHandle, outputfile, 64: ? outputfile,,"DDoc outputfile"
  IF FontSize THEN
     dpFont iHandle, FontStyle,FontSize,DefaultColor,DefaultFont$
     dpFont iHandle, FontStyle,12,DefaultColor,DefaultFont$
 GOSUB PrintHeading
  'Assets
  FOR x = 1 TO UBOUND(rsAssets)
    szAssets = rsAssets(x) '+ " current height" + STR$(AssetsHeight)
    GOSUB PrintAssetsDetailLine
    IF height => PageHeightMaximum THEN
      INCR pagenum
      dpNewPage iHandle,%ddoc_PAPER_LETTER, TheStyle, TheBin
      AssetsHeight = 2  'start new page
  IF NODIALOG THEN endCode = %DDOC_END_PRINT_NODIALOG
  'IF DpSpecifyPrinter(Ihandle,zPrinterName)THEN endcode% = %DDOC_END_SPECIFIC_PRINTER
  SLEEP 200
  dpEndDoc iHandle, EndCode
PrintHeading:
   dpFont ihandle, %DDOC_FONTNORMAL + %DDOC_FONTBOLD, 13, %vbGreen, "Arial"
   dpText ihandle, 4.25, 1.1, %DDOC_CENTER, "" & gName
   dpFont ihandle, %DDOC_FONTNORMAL + %DDOC_FONTBOLD, 12, %vbRed, "Arial"
   dpText IHandle, 4.25, 1.3, %DDOC_CENTER, "" & gAddress
   dpFont ihandle, %DDOC_FONTNORMAL + %DDOC_FONTUNDERLINE + %DDOC_FONTBOLD, 12, %vbBlack, "Arial"
   dpText IHandle, 4.25, 1.5, %DDOC_CENTER, "General Ledger Summary Report"
   dpText IHandle, 4.25, 1.8, %DDOC_CENTER, "Date Range: " & sFrom  & " To  " & sTo
   dpLine IHandle, .5, 10.3, 8, 10.3, 1, %vbBlack
   dpLine IHandle, .5, 10.8, 8, 10.8, 1, %vbBlack
PrintAssetsDetailLine:
  dpFont ihandle, %DDOC_FONTNORMAL + %DDOC_FONTUNDERLINE + %DDOC_FONTBOLD, 11, %vbBlack, "Arial"
  dpText IHandle, .5, 6.8, %DDOC_LEFT, "Assets: "
  dpFont ihandle, %DDOC_FONTNORMAL, 11, %vbBlack, "Arial"
  dpText iHandle,LeftMargin, AssetsHeight,%ddoc_left,szAssets
  AssetsHeight+= lineheight
RETURN
QuoteslSelAry is very convenient.
Some may prefer to loop through the recordset and optionally create an array with only certain items.
Since SQLite is embedded with PowerBASIC, the formatting of the recordset can be done with PowerBASIC or SQLite.
I agree with you. But I have used slSel for a long time now. Just starting to get a hang of slSelAry and I am learning a lot from you.
Best regards.
Fredrick Ughimi
Hello CJ,
I ran your last code. The issue is using Recordset(column,row) to get just the two columns I need out the lot. It seems its not possible. I might have to resort to using slSEL and loop through the records. This also has its issues using DDOC, that is why I wanted to use the slSELAry in the first place.
Regards.
Fredrick Ughimi
Hellon CJ,
>>Do you get a message when I post a response?
No. I guess because I don't use the email here anymore. I tried changing it to my current email without success.
>>1. SQLiteDate function is returning yyyy-dd-MM
It returns yyyy-MM-dd from dd-MM-yyyy here:
#COMPILE EXE
#DIM ALL
    LOCAL sFrom AS STRING
    LOCAL sTo AS STRING
    sTo = "29-05-2019"
    ? " " & SQLiteDate(sFrom)
>> 2 & 3.
'? Join$(rs(),$CRLF),,"Data in array".  Was commented out in my codes above, because I don't use it when I want display recordset in DDOC. Check my code above.
Fredrick Ughimi
This might work with ddoc
MACRO WRAP(p1)   = WRAP$(p1,$SQ,$SQ)
MACRO UNWRAP(p1) = UNWRAP$(p1,$SQ,$SQ)
MACRO BindT(p1)  = slBuildBindDat((p1),"T")
 LOCAL rs(),sFrom,sTo,sAccountType AS STRING
 LOCAL cols,rows,tabstops() AS LONG
 LOCAL sb AS ISTRINGBUILDERA
 sb = CLASS "STRINGBUILDERA"
 CreateTestData
 'AccountType Report
 sFrom = "01-01-2019"
 sTo   = "28-05-2019"
 sAccountType = WRAP("Assets")
 sb.clear
 sb.add "SELECT AccountName, printf('%.2f',SUM(Credit)*.01) as CreditSUM"
 sb.add " FROM tblJournalEntry"
 sb.add " WHERE Date BETWEEN " + SQLiteDate(sFrom)  + " AND " + SQLiteDate(sTo)
 sb.add " and AccountType ="   + sAccountType       + " GROUP BY AccountName"
 slselary(sb.string,rs(),"E0")
 IF slGetErrorNumber THEN
  ? sb.string+$CR+$CR+slGetError,%MB_ICONERROR,EXE.NAME$
 cols = UBOUND(rs,1)
 rows = UBOUND(rs,2)
 IF rows < 1 THEN
  ? "Data not found",%MB_SYSTEMMODAL,EXE.NAME$
 REDIM tabstops(1 TO 99) 'avoid assigning too many
 ARRAY ASSIGN tabstops() = 1,40
 PrintReport rs(),tabStops()
FUNCTION PrintReport(rs() AS STRING,tabStops() AS LONG) AS LONG
 LOCAL c,r,linecounter AS LONG
 LOCAL sLine AS STRING
 FOR r = 1 TO  UBOUND(rs,2)
  sLine = SPACE$(80)
  FOR c = 1 TO UBOUND(rs,1)
   MID$(sLine,tabstops(c)) = rs(c,r)
  INCR LineCounter
  ? sLine,,USING$("LineCounter #",LineCounter)
 FUNCTION = WRAP$(MID$(sDate,7,4) & "-" & MID$(sDate,4,2) & "-" & MID$(sDate,1,2),$SQ,$SQ)
SUB CreateTestData
 LOCAL x,y AS LONG
 LOCAL s AS STRING
 slOpen "junk1.db3","C"
 slexe  "drop table if exists tblJournalEntry"
 slexe  "create table tblJournalEntry(AccountName,AccountType,Date,Credit INTEGER)"
 FOR x = 1 TO 3
  FOR y = 1 TO 3
   s =  bindt("account"+FORMAT$(y)) + bindt("Assets") + bindt("2019-05-28") + bindi(STR$(y))
   slexebind "insert into tblJournalEntry values(?,?,?,?)",s
Fredrick Ughimi
Hello CJ,
Thanks a lot. I am going to try it later when electricity on or when I put on my generator by 7pm Nigeria time.
Kind regards.
Hope you get the power working!
I hard-coded parse$, but that should be modified to accept a variable number of columns.
PrintReport() could be modified to print many different reports.
It could be done in different ways including using a 2-dimensional array.
I like it.
This is what I see (click image)
You cannot view this attachment.
%vbBlack=&H0&:%vbRed=&HFF&:%vbGreen=&HFF00&:%vbYellow=&HFFFF&:%vbBlue=&HFF0000
%vbMagenta=&HFF00FF:%vbCyan=&HFFFF00:%vbWhite=&HFFFFFF:%vbGrey=&HC0C0C0:%LIGHT_SHADE=&HE0E0E0
GLOBAL gName,gAddress AS STRING
FUNCTION PBMAIN () AS LONG 'fredrick10.bas
 gName="Green line":gAddress = "Red line"
 CreateTestData
 sTo   = "28-05-2019"
 sb.clear
 slselary(sb.string,rs(),"Q9cE0")
 IF UBOUND(rs) < 1 THEN
 PrintReport rs(),sFrom,sTo
FUNCTION PrintReport(rsAssets() AS STRING,sFrom AS STRING, sTo AS STRING) AS LONG
  LOCAL iHandle,EndCode,TheBin,TheStyle,DefaultZoom,NoDialog,x,pagenum,fontsize,fontstyle,defaultcolor AS LONG
  LOCAL zOutputFile,zDocTitle,zDefaultFont AS ASCIIZ * 64
  LOCAL lineheight,LeftMargin AS SINGLE  'height deleted
  defaultzoom = %DDOC_ZOOM75
  zdefaultFont = "Courier New"
  fontsize = 8
  'topmargin= 1.6    'not in use
  LeftMargin = 0.5
  AssetsHeight = 1.0
  zdoctitle = "Mega-Net ERP - General Ledger Summary Report"
  DefaultZoom=%DDOC_ZOOMFIT + %DDOC_VIEWBUILD
  'DefaultZoom=%DDOC_ZOOM75  + %DDOC_VIEWBUILD
  'DefaultZoom=%DDOC_ZOOM100 + %DDOC_VIEWBUILD
                       zDocTitle, _
                       zoutputfile,_
                       %DDOC_INCH,_
                       TheBin,_
                       DefaultZoom&)
  IF ihandle < 1 THEN
    SELECT CASE ihandle
        ?  zoutputfile + " already exists so will delete document",,"dpStartDoc"
        KILL zoutputfile
  GOSUB PrintHeading
  dpFont ihandle, %DDOC_FONTNORMAL, 11, %vbBlack, "Courier"
  LOCAL s AS STRING
  szAssets = SPACE$(80)
    LSET szAssets =      PARSE$(rsAssets(x),$TAB,1)
    MID$(szAssets,20) =  PARSE$(rsAssets(x),$TAB,2)
    MID$(szAssets,40) = "current height" + STR$(AssetsHeight)
    'IF height => PageHeightMaximum THEN
    IF AssetsHeight => PageHeightMaximum THEN
      INCR pagenum
      GOSUB PrintHeading
  SLEEP 200
PrintHeading:
   AssetsHeight = 2.5
   dpText IHandle, .5, AssetsHeight, %DDOC_LEFT, "Assets: "
   AssetsHeight+= lineheight +.05 'looks a bit better
RETURN
  'dpFont ihandle, %DDOC_FONTNORMAL, 11, %vbBlack, "Arial"
RETURN
SUB CreateTestData
 LOCAL acctnum AS LONG
 LOCAL counter AS LONG
 LOCAL s AS STRING
 'slexe  "drop table if exists tblJournalEntry"
 slexe  "create table if not exists tblJournalEntry(AccountName,AccountType,Date,Credit INTEGER)"
 slexe "begin exclusive"
 FOR counter = 1 TO 1    'insert this many records into acctnum
  FOR acctnum = 1 TO 100 'number of accounts
   s =  bindt("account"+FORMAT$(acctnum)) + bindt("Assets") + bindt("2019-05-28") + bindi(STR$(acctnum))
 slexe "end"
%DropTable = 0
GLOBAL gbytes AS LONG
FUNCTION PBMAIN () AS LONG  'fredrick11.bas
  LOCAL sIpAddress AS STRING, portnumber AS LONG
  'sIpAddress = "" 'unremark to test server
  'portnumber =    'unremark to test server
  IF LEN(sIpAddress) THEN
    IF slConnect(sIpAddress,portnumber,"E0") THEN
      ? slGetError,,USING$("&  port #",sIpaddress,portnumber)
  IF %DropTable THEN
  InsertData
  sTo   = "28-05-2019"
  sb.clear
 IF LEN(sIpAddress) THEN slDisconnect
 ? USING$("Bytes #,",gbytes),,"Done"
  fontsize = 8
  LeftMargin = 0.5
  AssetsHeight = 1.0
                       zDocTitle, _
                       zoutputfile,_
                       %DDOC_INCH,_
                       TheBin,_
                       DefaultZoom&)
  IF ihandle < 1 THEN
    SELECT CASE ihandle
        KILL zoutputfile
  GOSUB PrintHeading
  LOCAL s AS STRING
      INCR pagenum
      GOSUB PrintHeading
  SLEEP 200
PrintHeading:
   AssetsHeight = 2.5
RETURN
RETURN
SUB InsertData
  LOCAL x         AS LONG
  LOCAL numaccts  AS LONG
  LOCAL numrecs   AS LONG
  LOCAL changes   AS LONG
  LOCAL bytes     AS LONG
  gbytes = 0
  numaccts   = 99
  numrecs    = 100
  DIM s(1 TO numaccts * numrecs) AS STRING
  changes = slgetchangecount("T")
  FOR acctnum = 1 TO numaccts  'account
    FOR x =1 TO numrecs        'insert this many into account
      INCR counter
      s(counter) = bindt(USING$("Acct #",acctnum)) + bindt("Assets") + bindt("2019-05-28") + bindi(STR$(acctnum))
      gbytes+=LEN(s(counter))
  slexebind "insert into tblJournalEntry values(?,?,?,?)",JOIN$(s(),""),"V4"
  slexe "end"
Fredrick Ughimi
Hello CJ,
All versions of your latest codes worked great. I need to add more recordsets to make the full report.
The code below was my initial effort before I posted a limited array version. The only problem I have with this one is that, whenever I add, modify or delete record(s) the items fall out of position. If I could solve that I would be good:
Method ReportGeneralLedgerSummary(ByVal nCbHndl As Long) As Long
          Local LineSpacing!,iHandle%,Row!,TopMargin!,PageSize!,PageNumber&
          Local detailline As Asciiz * 200
          Local DetailLine1 As Asciiz * 200
          Local DetailLine2 As Asciiz * 200
          Local DetailLine3 As Asciiz * 200
          Local lTotalRecords&
          Local SNo As Long
          Local dTotalIncome As Double
          Local dTotalExpenses As Double
          Local dBalance As Double
          Local sFrom As String
          Local sTo As String
          Local st      As String
          Dim a(10) As String
          Local i As Long
          LineSpacing = .2
          TopMargin   = .5
          PageSize    = 7
          ihandle% = dpStartDoc(0,"Mega-Net ERP - General Ledger Summary Report","",%DDOC_INCH, %DDOC_PAPER_A4, %DDOC_PORTRAIT, %DDOC_SYSTEM_DEFAULT, %DDOC_BIN_AUTO Or %DDOC_ALLOWSMTP Or %DDOC_ALLOWSAVE Or %DDOC_ZOOMFIT)
          If ihandle < 1 Then
               MsgBox "Could not StartDoc. Error number" + Str$(Ihandle)
               GoTo EndProgram
          dpSetTabs iHandle, "L0.5W4 L4.0W1"
          Row = PageSize                            'force new heading
          sFrom = VD_GetText(nCbHndl, %ID_FRMGENARALLEDGERSUMMARYRPTDLG_DPKFROM)
          sTo = VD_GetText(nCbHndl, %ID_FRMGENARALLEDGERSUMMARYRPTDLG_DPKTO)
          ReportsInformation()
'          'Revenue
'          slSel "SELECT Sum(Credit) As TotalIncome, * FROM tblJournalEntry WHERE Date BETWEEN '" + SQLiteDate(sFrom) + "' AND '" + SQLiteDate(sTo) + "' AND AccountType = 'Revenue' GROUP BY AccountType"
'          If IsTrue slGetRow() Then
'             dTotalIncome = Val(slFN("TotalIncome"))
'          End If
'          slCloseSet
'          slSel "SELECT Sum(Debit) As TotalExpenses, * FROM tblJournalEntry WHERE Date BETWEEN '" + SQLiteDate(sFrom) + "' AND '" + SQLiteDate(sTo) + "' AND AccountType = 'Expense' GROUP BY AccountType"
'             dTotalExpenses = Val(slFN("TotalExpenses"))
'          End If
'          slCloseSet
          slSel "Select AccountName, AccountType, Date, SUM(Credit) as CreditSUM From tblJournalEntry " & _
          "WHERE Date BETWEEN '" + SQLiteDate(sFrom) + "' AND '" + SQLiteDate(sTo) + "' AND AccountType = 'Revenue' GROUP BY AccountName"
          Do While slGetRow()
            If Row => PageSize Then
               If PageNumber Then      'If first page don't need a new page
                  dpNewPage iHandle%,  %ddoc_PAPER_A4, %DDOC_PORTRAIT,  %DDOC_BIN_AUTO
               Incr PageNumber
               Local hjpg As Long
                 hjpg = dpAddGraphic(ihandle%, VD_App.Path & "Logo.jpg")
                 If hjpg Then
                    dpDrawGraphic ihandle%, hjpg,3.5,.2,2,1
               dpText iHandle%, .5,TopMargin,  %DDOC_Left,"Page: "+ Str$(PageNumber)+""
               'dpText iHandle%, .5,TopMargin + .2,  %DDOC_Left,"Total Accounts:  "+ Str$(lTotalRecords&)+""
               dpText iHandle%, 6,TopMargin,  %DDOC_Left,"Date: "+ PBDate(Date$)+""
               dpText iHandle%, 6,TopMargin +.2,  %DDOC_Left,"Time: "+ Time$+""
               row =TopMargin + LineSpacing * 4
               dpFont ihandle%, %DDOC_FONTNORMAL + %DDOC_FONTBOLD, 13, %vbGreen, "Arial"
               dpFont ihandle%, %DDOC_FONTNORMAL + %DDOC_FONTBOLD, 12, %vbRed, "Arial"
               dpText IHandle%, 4.25, 1.3, %DDOC_CENTER, "" & gAddress
               dpFont ihandle%, %DDOC_FONTNORMAL + %DDOC_FONTUNDERLINE + %DDOC_FONTBOLD, 12, %vbBlack, "Arial"
               dpText IHandle%, 4.25, 1.5, %DDOC_CENTER, "General Ledger Summary Report"
               dpText IHandle%, 4.25, 1.8, %DDOC_CENTER, "Date Range: " & sFrom  & " To  " & sTo
               dpFont ihandle%, %DDOC_FONTNORMAL + %DDOC_FONTUNDERLINE + %DDOC_FONTBOLD, 11, %vbBlack, "Arial"
               dpText IHandle%, .5, 2.4, %DDOC_LEFT, "Revenue (Income): "
               'dpText IHandle%, 4.5, 2.4, %DDOC_RIGHT, Format$(dTotalIncome, "#,.00")
               'dpText IHandle%, .5, 3.3, %DDOC_LEFT, "Expenses: "
               'dpText IHandle%, 4.5, 3.3, %DDOC_RIGHT, Format$(dTotalExpenses, "#,.00")
               dBalance = dTotalIncome - dTotalExpenses
               dpFont ihandle%, %DDOC_FONTNORMAL + %DDOC_FONTUNDERLINE + %DDOC_FONTBOLD, 10, %vbBlack, "Arial"
               dpText IHandle%, .5, 5.8, %DDOC_LEFT, "Net Profit: "
               'dpText IHandle%, 4.5, 5.8, %DDOC_RIGHT, Format$(dBalance, "#,.00")
               'dpText IHandle%, .5, 6.1, %DDOC_LEFT, "Assets: "
               'dpText IHandle%, .5, 9.3, %DDOC_LEFT, "Equity: "
               dpLine IHandle%, .5, 10.3, 8, 10.3, 1, %vbBlack
               dpLine IHandle%, .5, 10.8, 8, 10.8, 1, %vbBlack
               dpTabText iHandle%, Row + 0.8, "    " & $CrLf & " Total Debits " & $CrLf & " Total Credits " & $CrLf & "Net Movement"
               dpFont ihandle%, %DDOC_FONTNORMAL, 9, %vbBlack, "San Serif"
               row =  row + LineSpacing * 2
             DetailLine$ =  _
              slFN("AccountName") + $Tab + _
              " " & $CrLf & _
              Format$(Val(slFN("CreditSUM")), "#,.00")
            dpTabText iHandle%, Row + 1.0, DetailLine
            Row = Row + LineSpacing                    'increment line counter
          Loop
          'Expenses
          slSel "Select AccountName, AccountType, Date, SUM(Debit) as DebitSUM From tblJournalEntry " & _
          "WHERE Date BETWEEN '" + SQLiteDate(sFrom) + "' AND '" + SQLiteDate(sTo) + "' AND AccountType = 'Expenses' GROUP BY AccountName"
          Do While slGetRow()
          DetailLine1$ =  _
              Format$(Val(slFN("DebitSUM")), "#,.00")
              dpTabText iHandle%, Row + 1.6, DetailLine1
          Loop
          'Assets
          " WHERE Date BETWEEN '" + SQLiteDate(sFrom) + "' AND '" + SQLiteDate(sTo) + "' AND AccountType = 'Assets' GROUP BY AccountName"
          Do While slGetRow()
          DetailLine2$ =  _
              dpTabText iHandle%, Row + 3.8, DetailLine2
          Loop
          'Equity
          "WHERE Date BETWEEN '" + SQLiteDate(sFrom) + "' AND '" + SQLiteDate(sTo) + "' AND AccountType = 'Equity' GROUP BY AccountName"
          Do While slGetRow()
          DetailLine3$ =  _
              " " & $CrLf & _
              dpTabText iHandle%, Row + 6.0, DetailLine3
          Loop
          dpEndDoc iHandle%, %DDOC_END_VIEW + %DDOC_END_PRINT
    EndProgram:
    End Method
#10
I don't see the line counter Row& being reset after a new page.
Never mind, I see row = pagesize
The previous code used Gosub when a new page and gosub to detail line, which was nice.
Totally different code.
It may be that the Row is not incremented correctly after each print?
I also saw a $CRLF in the code (don't know what ddoc would do with that?)
In your previous code you correctly checked the line counter after each print.
Might do that again:
GOSUB PrintDetailLine1
If linecounter => PageHeightMaximum THEN
GOSUB PrintDetailLine2
Fredrick Ughimi
Hello CJ,
You are right. It had no effect. I was just trying different things to space out the Credit and Debit to be on different vertical lines. I know what to do about that.
I will tryout your suggestions tomorrow and see it goes. It is 1.16am here already.
Thanks a bunch.
#13
Aligning non-fixed length fonts is in the ddoc demo in Fancy text.
The TestP32.Bas demo needs a slight change in WinMain to compile with PbWin10.
BYVAL lpCmdLine    AS ASCIIZ PTR, _
Here is the line that should do what you want:
dpText hFile%, 4.25, 4.15, %DDOC_DECIMAL, "Finally, decimal aligned  $9.99"
Fredrick Ughimi
Hello CJ,
>> %DDOC_DECIMAL
I must overlooked this. Thanks for bringing it to my notice. As I mentioned to you earlier I am making great progress in the report using post #7 as the base.
