October 18, 2021, 09:22:13 PM
Returning Selected Columns Only In slSelAry
Started by Fredrick Ughimi, May 28, 2019, 08:01:48 PM
Fredrick Ughimi
June 05, 2019, 06:02:40 PM #15 Last Edit: June 05, 2019, 07:25:31 PM by Fredrick Ughimi
Never mind. I think I know what to do.
Fredrick Ughimi
Hello CJ,
This is what I came up with using slSEL. Just what I wanted. I think slSEL is more suitable for a report like this. Thanks a million.
#COMPILE EXE
#DIM ALL
#INCLUDE "sqlitening.inc"
#INCLUDE "ddoc_p32.inc"
%vbBlack=&H0&:%vbRed=&HFF&:%vbGreen=&HFF00&:%vbYellow=&HFFFF&:%vbBlue=&HFF0000
%vbMagenta=&HFF00FF:%vbCyan=&HFFFF00:%vbWhite=&HFFFFFF:%vbGrey=&HC0C0C0:%LIGHT_SHADE=&HE0E0E0
FUNCTION PBMAIN () AS LONG 'fredrick10.bas
 slOpen "meganetERPDB.db3","C"
 PrintReport
FUNCTION PrintReport() AS LONG
  LOCAL PageHeightMaximum AS SINGLE
  LOCAL iHandle,EndCode,TheBin,TheStyle,DefaultZoom,NoDialog,x,pagenum,fontsize,fontstyle,defaultcolor AS LONG
  LOCAL zOutputFile,zDocTitle,zDefaultFont AS ASCIIZ * 64
  LOCAL lineheight,LeftMargin AS SINGLE  'height deleted
  LOCAL AssetsHeight AS SINGLE
  LOCAL EquityHeight AS SINGLE
  LOCAL RevenueHeight AS SINGLE
  LOCAL ExpensesHeight AS SINGLE
  LOCAL NetProfitHeight AS SINGLE
  LOCAL szExpensesAccount AS ASCIIZ * 200
  LOCAL szExpensesAmount AS ASCIIZ * 100
  LOCAL szRevenueAccount AS ASCIIZ * 200
  LOCAL szRevenueAmount AS ASCIIZ * 100
  LOCAL szEquityAccount AS ASCIIZ * 200
  LOCAL szEquityAmount AS ASCIIZ * 100
  LOCAL szAssetsAccount AS ASCIIZ * 200
  LOCAL szAssetsAmount AS ASCIIZ * 100
  LOCAL sName,sAddress, sFrom, sTo AS STRING
  LOCAL dTotalRevenue, dTotalExpenses, dNetProfit, dTotalCredit, dTotalDebit AS DOUBLE
  sName="Green line":sAddress = "Red line"
  sFrom = "01-01-2019"
  sTo   = "28-05-2019"
  PageHeightMaximum = 10.1  'inches
  defaultzoom = %DDOC_ZOOM75
  zdefaultFont = "Courier New"
  TheStyle = %ddoc_Portrait
  fontsize = 8
  TheBin = %DDOC_Bin_Auto '7
  'topmargin= 1.6    'not in use
  lineheight = .1666 '1/6  'each line height
  LeftMargin = 0.5
  zdoctitle = "Mega-Net ERP - General Ledger Summary Report"
  DefaultZoom=%DDOC_ZOOMFIT + %DDOC_VIEWBUILD
  'DefaultZoom=%DDOC_ZOOM75  + %DDOC_VIEWBUILD
  'DefaultZoom=%DDOC_ZOOM100 + %DDOC_VIEWBUILD
  ihandle = dpStartDoc(0,_
                       zDocTitle, _
                       zoutputfile,_
                       %DDOC_INCH,_
                       %DDOC_PAPER_A4,_
                       %DDOC_SYSTEM_DEFAULT, _
                       TheBin,_
                       DefaultZoom&)
  IF ihandle < 1 THEN
    SELECT CASE ihandle
      CASE %DDOC_NOHANDLES  : ? "no file handles",,"dpStartDoc"
      CASE %DDOC_BADFILE    : ? "bad file name",,  "dpStartDoc"
      CASE %DDOC_FILEEXISTS
        ?  zoutputfile + " already exists so will delete document",,"dpStartDoc"
        KILL zoutputfile
        IF ERR THEN ? "Could not delete file",,EXE.NAME$
      CASE ELSE:      ?  "Error code" + STR$(iHandle),,"dpStartDoc"
  GOSUB PrintHeading
  'Revenue
  dpFont ihandle, %DDOC_FONTNORMAL, 8, %vbBlack, "Courier"
   slSel "Select AccountName, AccountType, Date, SUM(Credit) as CreditSUM From tblJournalEntry " & _
   "WHERE Date BETWEEN '" + mySQLiteDate(sFrom) + "' AND '" + mySQLiteDate(sTo) + "' AND AccountType = 'Revenue' GROUP BY AccountName"
    DO WHILE slGetRow()
      szRevenueAccount = slFN("AccountName")
      szRevenueAmount = FORMAT$(VAL(slFN("CreditSUM")), "#,.00")
    GOSUB PrintRevenueDetailLine
    'IF height => PageHeightMaximum THEN
    IF RevenueHeight => PageHeightMaximum THEN
      INCR pagenum
      dpNewPage iHandle,%ddoc_PAPER_LETTER, TheStyle, TheBin
      GOSUB PrintHeading
      dpFont ihandle, %DDOC_FONTNORMAL, 8, %vbBlack, "Arial"
  LOOP
  SLEEP 200
  'Expenses
  dpFont ihandle, %DDOC_FONTNORMAL, 9, %vbBlack, "Courier"
  slSel "Select AccountName, AccountType, Date, SUM(Debit) as DebitSUM From tblJournalEntry " & _
  "WHERE Date BETWEEN '" + mySQLiteDate(sFrom) + "' AND '" + mySQLiteDate(sTo) + "' AND AccountType = 'Expenses' GROUP BY AccountName"
  DO WHILE slGetRow()
      szExpensesAccount =  slFN("AccountName")
      szExpensesAmount = FORMAT$(VAL(slFN("DebitSUM")), "#,.00")
    GOSUB PrintExpensesDetailLine
    IF ExpensesHeight => PageHeightMaximum THEN
      INCR pagenum
      GOSUB PrintHeading
      dpFont ihandle, %DDOC_FONTNORMAL, 11, %vbBlack, "Arial"
 LOOP
  SLEEP 200
  'Assets
  dpFont ihandle, %DDOC_FONTNORMAL, 5, %vbBlack, "Courier"
  LOCAL s AS STRING
  " WHERE Date BETWEEN '" + mySQLiteDate(sFrom) + "' AND '" + mySQLiteDate(sTo) + "' AND AccountType = 'Assets' GROUP BY AccountName"
  DO WHILE slGetRow()
      szAssetsAccount = slFN("AccountName")
      szAssetsAmount = FORMAT$(VAL(slFN("DebitSUM")), "#,.00")
      GOSUB PrintAssetsDetailLine
    IF AssetsHeight => PageHeightMaximum THEN
      INCR pagenum
      GOSUB PrintHeading
  LOOP
  SLEEP 200
  'Equity
   "WHERE Date BETWEEN '" + mySQLiteDate(sFrom) + "' AND '" + mySQLiteDate(sTo) + "' AND AccountType = 'Equity' GROUP BY AccountName"
    DO WHILE slGetRow()
      szEquityAccount = slFN("AccountName")
      szEquityAmount = FORMAT$(VAL(slFN("CreditSUM")), "#,.00")
    GOSUB PrintEquityDetailLine
      INCR pagenum
      GOSUB PrintHeading
  LOOP
  SLEEP 200
  'Total Credit
  slSel "Select AccountName, AccountType, Date, SUM(Credit) as TotalCredit From tblJournalEntry " & _
          "WHERE Date BETWEEN '" + mySQLiteDate(sFrom) + "' AND '" + mySQLiteDate(sTo) + "'"
  IF ISTRUE slGetRow() THEN
     dTotalCredit = VAL(slFN("TotalCredit"))
  slCloseSet
  'Total Debit
  slSel "Select AccountName, AccountType, Date, SUM(Debit) as TotalDebit From tblJournalEntry " & _
     dTotalDebit = VAL(slFN("TotalDebit"))
  slCloseSet
  GOSUB PrintTotalsDetailLine
  'Revenue
  slSel "Select AccountName, AccountType, Date, SUM(Credit) as TotalRevenue From tblJournalEntry " & _
          "WHERE Date BETWEEN '" + mySQLiteDate(sFrom) + "' AND '" + mySQLiteDate(sTo) + "' AND AccountType = 'Revenue'"
     dTotalRevenue = VAL(slFN("TotalRevenue"))
  slCloseSet
  'GOSUB PrintHeading
  'Expenses
  slSel "Select AccountName, AccountType, Date, SUM(Debit) as TotalExpenses From tblJournalEntry " & _
          "WHERE Date BETWEEN '" + mySQLiteDate(sFrom) + "' AND '" + mySQLiteDate(sTo) + "' AND AccountType = 'Expenses'"
     dTotalExpenses = VAL(slFN("TotalExpenses"))
  slCloseSet
  'GOSUB PrintHeading
  dNetProfit = dTotalRevenue - dTotalExpenses
  GOSUB PrintNetProfitDetailLine
  endCode = %DDOC_END_VIEW + %DDOC_END_DELETE
  dpEndDoc iHandle, EndCode
PrintHeading:
   dpFont ihandle, %DDOC_FONTNORMAL + %DDOC_FONTBOLD, 13, %vbGreen, "Arial"
   dpText ihandle, 4.25, 1.1, %DDOC_CENTER, "" & sName
   dpFont ihandle, %DDOC_FONTNORMAL + %DDOC_FONTBOLD, 12, %vbRed, "Arial"
   dpText IHandle, 4.25, 1.3, %DDOC_CENTER, "" & sAddress
   dpFont ihandle, %DDOC_FONTNORMAL + %DDOC_FONTUNDERLINE + %DDOC_FONTBOLD, 12, %vbBlack, "Arial"
   dpText IHandle, 4.25, 1.5, %DDOC_CENTER, "General Ledger Summary Report"
   dpText IHandle, 4.25, 1.8, %DDOC_CENTER, "Date Range: " & sFrom  & " To  " & sTo
   dpLine IHandle, .5, 10.3, 8, 10.3, 1, %vbBlack
   'dpText IHandle, .5, 10.6, %DDOC_LEFT, "Total Debit: " & FORMAT$(dTotalDebit, "#,.00")
   'dpText IHandle, 3.5, 10.6, %DDOC_LEFT, "Total Credit: " & FORMAT$(dTotalCredit, "#,.00")
   dpLine IHandle, .5, 11.0, 8, 11.0, 1, %vbBlack
   dpFont ihandle, %DDOC_FONTNORMAL + %DDOC_FONTUNDERLINE + %DDOC_FONTBOLD, 11, %vbBlack, "Arial"
   RevenueHeight = 2.5
   dpText IHandle, .5, RevenueHeight, %DDOC_LEFT, "Revenue: "
   ExpensesHeight = 3.5
   dpText IHandle, .5, ExpensesHeight, %DDOC_LEFT, "Expenses: "
   NetProfitHeight = 6.5
   dpText IHandle, .5, NetProfitHeight, %DDOC_LEFT, "Net Profit: "
   AssetsHeight = 7.5
   dpText IHandle, .5, AssetsHeight, %DDOC_LEFT, "Assets: "
   EquityHeight = 9.0
   dpText IHandle, .5, EquityHeight, %DDOC_LEFT, "Equity: "
   RevenueHeight+= lineheight +.05 'looks a bit better
   ExpensesHeight+= lineheight +.05 'looks a bit better
   AssetsHeight+= lineheight +.05 'looks a bit better
   EquityHeight+= lineheight +.05 'looks a bit better
   'NetProfitHeight+= lineheight +.05 'looks a bit better
RETURN
PrintRevenueDetailLine:
  dpText iHandle,LeftMargin, RevenueHeight,%ddoc_left,szRevenueAccount
  dpText iHandle,7.0, RevenueHeight,%DDOC_DECIMAL,szRevenueAmount
RETURN
PrintExpensesDetailLine:
  dpText iHandle,LeftMargin, ExpensesHeight,%ddoc_left,szExpensesAccount
  dpText iHandle,5.0, ExpensesHeight,%ddoc_decimal,szExpensesAmount
RETURN
PrintNetProfitDetailLine:
  dpText iHandle,4.5, NetProfitHeight,%ddoc_left,FORMAT$(dNetProfit, "#,.00")
RETURN
PrintAssetsDetailLine:
  dpText iHandle,LeftMargin, AssetsHeight,%ddoc_left, szAssetsAccount
  dpText iHandle,5.0, AssetsHeight,%DDOC_DECIMAL, szAssetsAmount
RETURN
PrintEquityDetailLine:
  dpText iHandle,LeftMargin, EquityHeight,%ddoc_left, szEquityAccount
  dpText iHandle,7.0, EquityHeight,%DDOC_DECIMAL, szEquityAmount
RETURN
PrintTotalsDetailLine:
  'dpText iHandle,LeftMargin, AssetsHeight,%ddoc_left,szAssets
  dpText IHandle, 0.5, 10.6, %DDOC_LEFT, "Total: "
  dpText IHandle, 5.0, 10.6, %DDOC_DECIMAL, FORMAT$(dTotalDebit, "#,.00") & " Dr"
  'dpText IHandle, 5.7, 10.6, %DDOC_LEFT, "Total Credit: "
  dpText IHandle, 7.0, 10.6, %DDOC_DECIMAL, FORMAT$(dTotalCredit, "#,.00") & " Cr"
RETURN
FUNCTION mySQLiteDate(sDate AS STRING) AS STRING
     'From dd-MM-yyyy To yyyy-MM-dd
     FUNCTION = MID$(sDate,7,4) & "-" & MID$(sDate,4,2) & "-" & MID$(sDate,1,2)
June 06, 2019, 11:07:36 AM #17 Last Edit: June 06, 2019, 11:10:00 AM by cj
I think there should only be one line counter.
Lines will print over themselves in this demo.
#COMPILE EXE
#DIM ALL
%DropTable = 1
MACRO WRAP(p1)  = WRAP$(p1,$SQ,$SQ)
MACRO UNWRAP(p1) = UNWRAP$(p1,$SQ,$SQ)
MACRO BindT(p1)  = slBuildBindDat((p1),"T")
GLOBAL gName,gAddress AS STRING
GLOBAL gbytes AS LONG
 slOpen "junk1.db3","C"
 IF %DropTable THEN
  slexe  "drop table if exists tblJournalEntry"
 slexe  "create table if not exists tblJournalEntry(AccountName,AccountType,Date,Credit INTEGER, Debit INTEGER)"
 InsertData
 gName="Green line":gAddress = "Red line"
 'slOpen "meganetERPDB.db3","C"
 PrintReport
  sTo  = "28-05-2019"
  fontsize = 8
  LeftMargin = 0.5
                      zDocTitle, _
                      zoutputfile,_
                      %DDOC_INCH,_
                      %DDOC_PAPER_A4,_
                      TheBin,_
                      DefaultZoom&)
  IF ihandle < 1 THEN
    SELECT CASE ihandle
        KILL zoutputfile
  GOSUB PrintHeading
  'Revenue
    DO WHILE slGetRow()
      INCR pagenum
      GOSUB PrintHeading
  LOOP
  SLEEP 200
  'Expenses
  DO WHILE slGetRow()
      INCR pagenum
      GOSUB PrintHeading
 LOOP
  SLEEP 200
  'Assets
  LOCAL s AS STRING
  DO WHILE slGetRow()
      INCR pagenum
      GOSUB PrintHeading
  LOOP
  SLEEP 200
  'Equity
    DO WHILE slGetRow()
      INCR pagenum
      GOSUB PrintHeading
  LOOP
  SLEEP 200
  'Total Credit
  slCloseSet
  'Total Debit
  slCloseSet
  'Revenue
  slCloseSet
  'GOSUB PrintHeading
  'Expenses
  slCloseSet
  'GOSUB PrintHeading
PrintHeading:
  RevenueHeight = 2.5
  AssetsHeight = 7.5
  EquityHeight = 9.0
RETURN
RETURN
RETURN
RETURN
RETURN
RETURN
RETURN
SUB InsertData
  LOCAL x        AS LONG
  LOCAL acctnum  AS LONG
  LOCAL numaccts  AS LONG
  LOCAL numrecs  AS LONG
  LOCAL counter  AS LONG
  LOCAL bytes    AS LONG
  'gbytes = 0
  numaccts  = 99
  numrecs    = 100
  DIM s(1 TO numaccts * numrecs) AS STRING
  slexe "begin exclusive"
  FOR acctnum = 1 TO numaccts  'account
    FOR x =1 TO numrecs        'insert this many into account
      INCR counter
      s(counter) = bindt(USING$("Acct #",acctnum)) + bindt("Assets") + bindt("2019-05-28") + bindi(STR$(acctnum)) + bindi(STR$(acctnum))
      gbytes+=LEN(s(counter))
  slexebind "insert into tblJournalEntry values(?,?,?,?,?)",JOIN$(s(),""),"V5"
  slexe "end"
  counter = 0
  REDIM s(1 TO numaccts * numrecs) AS STRING
      INCR counter
      s(counter) = bindt(USING$("Acct #",acctnum)) + bindt("Revenue") + bindt("2019-05-28") + bindi(STR$(acctnum)) + bindi(STR$(acctnum))
  slexe "end"
Fredrick Ughimi
I would take a look at it later today. Thanks.
Instead of listing debits and then credits, how about different reports just listing the table?
DATE/CLIENT REPORT
DATE     CLIENT     TYPE           DEBIT       CREDIT    PAGE 1
6/6/19   1          Car            1000        1000
                    Car            3000          50
                    Car             400          20
6/7/19   2          Horse          1000        1000
                    Horse          3000          50
                    Horse           400          20
CLIENT/DATE REPORT
CLIENT   DATE       TYPE           DEBIT       CREDIT    PAGE 1
1        6/6/19     Car            1000        1000
                    Car            3000          50
                    Car             400          20
2        6/7/19     Horse          1000        1000
                    Horse          3000          50
                    Horse           400          20
Fredrick Ughimi
I see what you mean now. But I can't see the linecounter variable. Do you mean the lineheight?
Fredrick Ughimi
I have similar reports, the General Ledger Transactions Report and Journal Report.
But my final General Ledger Summary Report looks like the attached.
Fredrick Ughimi
Not quite. My General Ledger Transactions Report and Journal Report look very different. It would be interesting to have such variant report as you indicated.
Fredrick Ughimi
QuotePrintHeading:
   dpText ihandle, 4.25, 1.1, %DDOC_CENTER, "" & gName
   dpText IHandle, 4.25, 1.3, %DDOC_CENTER, "" & gAddress
   dpLine IHandle, .5, 10.8, 8, 10.8, 1, %vbBlack
   AssetsHeight = 2.5
I think I just followed your footsteps.
