July 23, 2021, 08:32:34 PM
SQLitening/MLG Demo (suggestions welcome)
Started by cj, June 22, 2019, 03:51:07 AM
June 22, 2019, 03:51:07 AM Last Edit: June 22, 2019, 10:59:49 PM by cj
Shows how easy it is to display 2-dimensional recordsets in MLG
MLG_PUT hGrid,rownum,colnum,sRecordSet(colnum,rownum),0
Pressing Enter key (at anytime) or clicking Run executes the SQL and fills grid.
Added statusbar 6/22/19  1:39AM CST
Suggestions welcome
MLG can be purchased from Gary Beene gbeene@airmail.net
#PBFORMS CREATED V2.01
#COMPILE EXE    'slMlg.bas
#DIM ALL
GLOBAL ghDlg AS DWORD
#PBFORMS BEGIN INCLUDES
#INCLUDE ONCE "WIN32API.INC"
#PBFORMS END INCLUDES
#INCLUDE ONCE "mlg.inc"
#INCLUDE ONCE "sqlitening.inc"
#PBFORMS BEGIN CONSTANTS
%IDC_GRID      =  100
%GridLabel      = 1010
%TEXT_DATABASE  = 1011
%TEXT_SQL      = 1012
%LBL_DATABASE  = 1013
%LBL_SQL        = 1014
%BTN_RUN        = 1015
%LBL_LABEL1    = 1016
%IDC_STATUSBAR1 = 1017
#PBFORMS END CONSTANTS
#PBFORMS DECLARATIONS
FUNCTION PBMAIN()
  ShowDIALOG1 0
SUB Resize
 LOCAL DialogWidth,DialogHeight AS LONG
 LOCAL GridWidth  ,GridHeight  AS LONG
 DIALOG  GET SIZE  ghDlg TO DialogWidth,DialogHeight            'dialog width,height
 CONTROL GET SIZE ghDlg,%IDC_GRID TO GridWidth  ,GridHeight    'grid  width,height
 CONTROL SET SIZE ghDlg,%IDC_GRID,  DialogWidth-14,GridHeight  'set grid width
 CONTROL REDRAW  ghDlg,%IDC_GRID
CALLBACK FUNCTION ShowDIALOG1Proc()
 LOCAL gridwidth,gridheight AS LONG
 LOCAL SelStart,SelEnd AS LONG
  SELECT CASE AS LONG CB.MSG
    CASE %WM_EXITSIZEMOVE
    Resize
    CASE %WM_INITDIALOG
    ghDlg = CB.HNDL
    CONTROL GET SIZE ghDlg,%GridLabel TO GridWidth ,GridHeight    'label size
    CONTROL SET SIZE ghDlg,%GridLabel,  DialogWidth-14,Gridheight  'set grid width
    CASE %WM_NCACTIVATE
      STATIC hWndSaveFocus AS DWORD
      IF ISFALSE CB.WPARAM THEN
        hWndSaveFocus = GetFocus()
      ELSEIF hWndSaveFocus THEN
        SetFocus(hWndSaveFocus)
        hWndSaveFocus = 0
    CASE %WM_COMMAND
      SELECT CASE AS LONG CB.CTL
        CASE %IDC_STATUSBAR1
        CASE %TEXT_DATABASE
        CASE %TEXT_SQL
          IF CB.CTLMSG = %EN_SETFOCUS THEN 'SQL input control got focus
            CONTROL SEND CB.HNDL, %TEXT_SQL,%EM_GETSEL, VARPTR(SelStart), VARPTR(SelEnd)
            CONTROL SEND CB.HNDL, %TEXT_SQl,%EM_SETSEL,SelEnd,SelEnd
        CASE %BTN_RUN
          IF CB.CTLMSG = %BN_CLICKED OR CB.CTLMSG = 1 THEN
            GridFromSQL
            CONTROL SET FOCUS CB.HNDL,%TEXT_SQl
        CASE %IDC_GRID
FUNCTION ShowDIALOG1(BYVAL hParent AS DWORD) AS LONG
  LOCAL lRslt AS LONG
  LOCAL hDlg  AS DWORD
  DIALOG NEW hParent, "", 286, 170, 768, 359, %WS_POPUP OR %WS_BORDER OR _
    %WS_DLGFRAME OR %WS_THICKFRAME OR %WS_CAPTION OR %WS_SYSMENU OR _
    %WS_MINIMIZEBOX OR %WS_MAXIMIZEBOX OR %WS_VISIBLE OR %DS_3DLOOK OR _
    %DS_NOFAILCREATE OR %DS_SETFONT, %WS_EX_LEFT OR %WS_EX_LTRREADING OR _
    %WS_EX_RIGHTSCROLLBAR, TO hDlg
  CONTROL ADD TEXTBOX,  hDlg, %TEXT_DATABASE, "", 43, 297, 99, 13
  CONTROL ADD TEXTBOX,  hDlg, %TEXT_SQL, "select * from parts limit 5", 42, _
    313, 441, 13
  CONTROL ADD LABEL,    hDlg, %GridLabel, "%GridLabel - Grid will display " + _
    "here", 0, 0, 752, 260
  CONTROL SET COLOR      hDlg, %GridLabel, %WHITE, %BLUE
  CONTROL ADD LABEL,    hDlg, %LBL_DATABASE, "Database", 5, 297, 32, 11
  CONTROL ADD LABEL,    hDlg, %LBL_SQL, "SQL", 5, 315, 23, 10
  CONTROL ADD BUTTON,    hDlg, %BTN_RUN, "Run", 5, 329, 23, 10
  CONTROL ADD LABEL,    hDlg, %LBL_LABEL1, "Press Enter or click Run", 5, _
    277, 324, 10
  CONTROL ADD STATUSBAR, hDlg, %IDC_STATUSBAR1, "Rows 0    Columns 0", 0, 0, _
    0, 0
#PBFORMS END DIALOG
  DIALOG SET TEXT hdlg,EXE.NAME$
  LOCAL Msg AS TagMsg
  LOCAL flag AS LONG  'prevent grid displaying twice when we set focus
  DIALOG SHOW MODELESS hDlg, CALL ShowDIALOG1Proc TO lRslt
  DO WHILE GetMessage(Msg, %NULL, 0, 0)
  IF IsDialogMessage(hDlg, Msg) = %FALSE THEN
    TranslateMessage Msg
    DispatchMessage  Msg
  IF msg.wparam = 13 THEN                      'enter pressed in any control
    'DIALOG SET TEXT ghDlg,USING$("ID #  Counter #",GetDlgCtrlID(GetFocus),gCounter)
    IF GetDlgCtrlID(GetFocus) = %TEXT_SQL THEN 'in %TEXT_SQL control?
      IF flag = 0 THEN GridFromSQL              'execute sql and MLG
      flag = flag XOR 1                        'toggle flag
      LOCAL selStart,SelEnd AS LONG
      CONTROL SEND hDlg, %TEXT_SQL,%EM_GETSEL, VARPTR(SelStart), VARPTR(SelEnd)
      CONTROL SEND hdlg, %TEXT_SQl,%EM_SETSEL,SelEnd,SelEnd
    CONTROL SET FOCUS hDlg,%TEXT_SQL          'always focus to sql input
  LOOP WHILE ISWIN(hDlg)
  FUNCTION = lRslt
FUNCTION GridFromSQL AS LONG
 LOCAL rownum,colnum,rows,cols AS LONG
 LOCAL x AS LONG,y AS LONG,gridwidth,gridheight,hGrid AS LONG
 LOCAL s AS STRING
 LOCAL sDatabase AS STRING
 LOCAL sql AS STRING
 LOCAL sRecordSet() AS STRING
 CONTROL GET TEXT ghDlg,%TEXT_DATABASE TO sDatabase
 CONTROL GET TEXT ghDlg,%TEXT_SQL  TO sql
 IF LEN(TRIM$(sDataBase)) = 0 THEN
  sDatabase = "sample.db3"
  sql = "select manuf,redref,product,language,cpu_os,media,type,pgroup,printf('%.2f',price*.01) as PRICE from parts limit 5"
  CONTROL SET TEXT ghDlg,%TEXT_Database,"sample.db3"
  CONTROL SET TEXT ghDlg,%TEXT_SQL,sql
  DIALOG REDRAW ghDlg
 slOpen sDatabase,"C E0"  'E0 we will handle open database error
 IF slGetErrorNumber THEN
  ? "Database name: " +  WRAP$(sdataBase,$DQ,$DQ) + $CR + slGetError,%MB_SYSTEMMODAL,"SQL Open"
 slSelAry sql,sRecordSet(),"E0"  'E0 we will handle SQL error
  ? CHR$(slGetError,$CR,"Database name: ",WRAP$(sdataBase,$DQ,$DQ),$CR,$CR,sql),%MB_SYSTEMMODAL,"SQL Error"
 rows = UBOUND(sRecordset,2)
 cols = UBOUND(sRecordset,1)
 s = USING$("r#/c#",Rows,cols) 'rows and columns
 CONTROL GET LOC ghdlg,%GridLabel TO x,y
 CONTROL GET SIZE ghdlg,%GridLabel TO gridwidth,gridheight
 CONTROL SHOW STATE ghDlg, %GridLabel, %SW_HIDE 'must hide grid position label
 CONTROL KILL ghDlg,%IDC_GRID                  'start a fresh grid
 CONTROL ADD "MYLITTLEGRID", ghDlg, %IDC_GRID, s, x, y, gridwidth,gridheight, %MLG_STYLE
 CONTROL HANDLE ghDlg, %IDC_GRID TO hGrid
 FOR rownum = 0 TO rows
  FOR colnum = 1 TO cols
 slClose
 CONTROL SET TEXT ghDlg,%IDC_STATUSBAR1,USING$("Rows #,    Columns #",rows,cols)
 Resize
July 09, 2019, 01:02:24 PM #1 Last Edit: July 10, 2019, 06:45:37 AM by cj
Instead of killing and adding grid this version uses MLG_PUTEX
It also leaves the scroll bars on at all times using /D switch
#DIM ALL
GLOBAL ghDlg,hGrid AS LONG
#RESOURCE "slMLG.pbr"
#INCLUDE ONCE "COMMCTRL.INC"
#INCLUDE ONCE "PBForms.INC"
%IDC_GRID      = 1009
%GridLabel      = 1010
%TEXT_SQL      = 1012
%LBL_SQL        = 1014
%BTN_RUN        = 1015
%LBL_LABEL1    = 1016
FUNCTION PBMAIN()
  ShowDIALOG1 %HWND_DESKTOP
SUB Resize
 'get size of dialog
 'get size of MLG
 IF GridWidth THEN 'if 0 then do not redraw
    Resize
    CASE %WM_INITDIALOG
    LOCAL s AS STRING
    ghDlg = CB.HNDL
    GridFromSQL
    CASE %WM_NCACTIVATE
        hWndSaveFocus = 0
    CASE %WM_CHAR
    CASE %WM_COMMAND
        CASE %TEXT_DATABASE
        CASE %TEXT_SQL
        CASE %BTN_RUN
            GridFromSQL
        CASE %IDC_GRID
  LOCAL lRslt AS LONG
  LOCAL hDlg  AS DWORD
  CONTROL ADD TEXTBOX,  hDlg, %TEXT_DATABASE, "sample.db3", 43, 297, 99, 13
  CONTROL ADD TEXTBOX,  hDlg, %TEXT_SQL, "select * from parts limit 234", 42, _
    313, 441, 13
    277, 324, 10
    0, 0
#PBFORMS END DIALOG
CONTROL SET TEXT hDlg,%TEXT_SQL, _
"select manuf,redref,product,language,cpu_os,media,type,pgroup,printf('%.2f',price*.01) as PRICE from parts"
  'DIALOG SET TEXT hdlg,EXE.NAME$
  LOCAL Msg AS TagMsg
    DispatchMessage  Msg
    'IF GetDlgCtrlID(GetFocus) = %TEXT_SQL THEN 'in %TEXT_SQL control?
      'CONTROL SET FOCUS hDlg,%TEXT_SQL          'focus to sql input control
    'END IF
  FUNCTION = lRslt
 LOCAL x AS LONG,y AS LONG,gridwidth,gridheight AS LONG
 LOCAL s AS STRING
 LOCAL sql AS STRING
 slOpen sDatabase,"C E0"  'E0 we will handle open database error open/close database each time called
 rows = UBOUND(sRecordset,2)  'SQLitening(col,row) order
 cols = UBOUND(sRecordset,1)  'SQLitening(col,row) order
 REDIM RowsCols(rows,cols) AS STRING 'MLG(row,col) order
 STATIC newgrid AS LONG
 IF newgrid = 0 THEN
  newgrid = 1
  CONTROL KILL ghDlg,  %IDC_GRID    'start a fresh grid
  s = USING$("r#/c#/d-0",Rows,cols) 'initial rows and columns  /d-0 don't hide scrollbars
  #IF %DEF(%MLG_UNLOCK)
  MLG_UNLOCK
  #ENDIF
 'Create MLG(Row,Col) from SQLitening(Col,Row)
  RowsCols(rownum,colnum) = sRecordSet(colnum,rownum)
 Mlg_PutEx hGrid,RowsCols(),-4,1    'put array to MLG in row,col order
 FOR x = 1 TO UBOUND(RowsCols,2)    'column names should have been in grid?
  MLG_PUT hGrid,0,x,RowsCols(0,x),1
 slClose
 Resize
