October 18, 2021, 09:58:52 PM
sqlite3.exe with two parameters
Started by Fim, June 24, 2019, 08:10:11 AM
Fim
According to https://sqlite.org/cli.html item 18, two parameters can be used.
This works ok:
sqlite3 winova.db3 .help
But not this:
sqlite3 winova.db3 .read export.sql
Then I got the error message: Usage: .read FILE
Am I doing something wrong or ....
/Fim W
Fim W
June 25, 2019, 12:08:08 AM #1 Last Edit: June 25, 2019, 12:12:06 AM by cj
Everything can be done within PowerBASIC using this shell routine.
https://sqlitening.planetsquires.com/index.php?topic=9743.msg26446;topicseen#msg26446
Fim
Fim W
June 25, 2019, 08:24:13 AM #3 Last Edit: June 25, 2019, 08:33:46 AM by cj Reason: Each SQL statement must be terminated with a semi-colon , not single quote
Welcome.  Hope it helps.
