CLI from PB
Started by cj, June 25, 2019, 12:06:16 AM
1. If $Viewfile has a length the output goes to a text file and is displayed using default text viewer.
2. If $Viewfile is remarked, the output goes to the command line environment.
3. All select statements must be terminated with a semi-colon.
4. Backup, clone, import, export, view sql, ...
5. Many commands can be sent at once by separating each semi-colon terminated command with a $CRLF
Example:
sdatabase= "sample.db3"
sheller "select * from parts;" + $CRLF
'SQLite3Sheller -  script processor  6/24/19
'All select statements must be terminated with a semi-colon.
'Many uses; including backup, clone, import, export, view sql, ...
DECLARE FUNCTION ShellExecute LIB "Shell32.dll" ALIAS "ShellExecuteA" ( _
    BYVAL hwnd AS DWORD, lpOperation AS ASCIIZ, lpFile AS ASCIIZ, _
    lpParameters AS ASCIIZ, lpDirectory AS ASCIIZ, BYVAL nShowCmd AS LONG) _
    AS DWORD
$CommandFile="cj.cmd" 'file read by SQLite3.exe
$BatchFile  ="cj.bat" 'file shelled to
'$ViewFile  ="cj.txt" '<---  remark to use cmd.exe or unremark to view .txt file
FUNCTION PBMAIN () AS LONG 'sqlite commands .modes ascii column html insert line list tabs tcl
 LOCAL s,sdatabase AS STRING
 #IF %DEF($ViewFile)
  s=CHR$(".output ",$ViewFile,$CRLF)
 #ENDIF
 s+= CHR$("select '10 records of '||count(*)||' records (.mode tab)' from parts;",$CRLF)
 s+= CHR$(".mode tabs",$CRLF)
 s+= CHR$("select rowid,redref,substr(product,1,40) from parts limit 10;",$CRLF)
 s+= CHR$("select '';",$CRLF)
 s+= CHR$("select '10 records of '||count(*)||' records (.mode csv)' from parts;",$CRLF)
 s+= CHR$(".mode csv",$CRLF)
 sheller sdatabase,s
 #IF %DEF($ViewFile)
  DisplayTextFile $ViewFile
 #ENDIF
FUNCTION sheller(sDataBase AS STRING,sCommands AS STRING) AS LONG
 LOCAL stemp AS STRING, h AS LONG
 h = FREEFILE
 OPEN $CommandFile FOR OUTPUT AS #h
 IF ERR THEN ? "Unable to open " + $CommandFile,%MB_SYSTEMMODAL,"Error":EXIT FUNCTION
 PRINT #h,sCommands;
 CLOSE #h
 h = FREEFILE
 OPEN $BatchFile FOR OUTPUT AS #h
 IF ERR THEN ? "Unable to open " + $BatchFile,%MB_SYSTEMMODAL,"Error":EXIT FUNCTION
 stemp = "sqlite3.exe " + sdatabase + " < " + $CommandFile
 PRINT #h,"@cls"
 PRINT #h,"@echo off"
 PRINT #h,stemp
 #IF NOT %DEF($ViewFile) 'viewfile not wanted
  PRINT #h,"pause"      'pause batch file so we can see results
 #ENDIF
 CLOSE #h
 #IF %DEF($ViewFile)
  h = SHELL($BatchFile,0)
 #ELSE
  h = SHELL($BatchFile)
 #ENDIF
FUNCTION DisplayTextFile(sFileName AS STRING) AS LONG
 LOCAL zFileName AS ASCIIZ * 257
 zFileName = sFileName
 ShellExecute (0, "OPEN", zFileName, BYVAL 0, CURDIR$, %SW_SHOWNORMAL)
