Is Auto Checkout Guests Candidate For Trigger?
Started by Fredrick Ughimi, September 05, 2019, 03:57:53 PM
Fredrick Ughimi
Hello,
I am stump trying to figure out how to automatically 'trigger' this sequence of SQL startements. I wonder if Trigger is the best condidate.
'Free room
slExe slBuildInsertOrUpdate("tblRoomRates", sRoomNo & $Nul & "Available", "RoomNo, Status", "RoomNo=" & sRoomNo)
'Copy record to History Table
Errorcode& = slExe("Insert into tblRegistrationHistory Select * From tblRegistration Where RowID = '" + sRecordNo + "'","E")
Delete Record
slEXE "Delete From tblRegistration WHERE DepartureDate <= date('now') AND DepartureTime <= time('12')"
But triggers are only triggered when an INSERT, DELETE or UPDATE occurs. I want the statements triggered when this conditions are met:
If (sDepartureDate < Date$) Or (sDepartureDate = Date$ And Time$ > "12") Then
Any help would be appreciated.
#1
Sorry, somebody else might have trigger logic.
Might be able to create a temporary table and create a trigger on it.
https://www.sqlitetutorial.net/sqlite-trigger/
A recordset could be created using a CASE statement
to test any conditions and write what to do for any
of those conditions.  When done, process the recordset.
CASE statements can test the same record multiple times
and can be nested.
#INCLUDE "sqlitening.inc"
FUNCTION PBMAIN AS LONG
 slopen ":memory:"
 slexe "create table t1(c1 integer)"
 FOR x& = -10 TO 10:slexe "insert into t1 values(" + STR$(x&) + ")":NEXT
 s$ = "select c1, "
 s$+= " case"
 s$+= "   when c1 > 0 THEN 'greater'"
 s$+= "   when c1 < 0 THEN 'less'"
 s$+= "  else             'equal'"
 s$+= " end as NewColName"
 s$+= " from t1"
 slselary s$,sarray$(),"Q9"
 ? JOIN$(sarray$(),$CR)
Fredrick Ughimi
Hello CJ,
Interesting. Trying to adapt your technique.
Thanks.
Fredrick Ughimi
Hello CJ,
Looks good. I would need to do some weeding.
How do I make this piece code activate itself without clicking anything to bring it to action? Thread?
#COMPILE EXE
#DIM ALL
FUNCTION CDate(Pbd AS STRING) AS STRING
     'Change PB date to mm-dd-yyyy to yyyy-mm-dd
     FUNCTION = MID$(Pbd,7,4) & "-" & MID$(Pbd,1,2) & "-" & MID$(Pbd,4,2)
 LOCAL x AS LONG
 LOCAL s$
 DIM sarray$()
 LOCAL Errorcode&
 LOCAL sRoomNo AS STRING
 LOCAL sRecordNo AS STRING
 sRoomNo = "501"
 slOpen ("GuestsProDB.db3","C")
 'Registration
  slExe BUILD$("Create Table If Not Exists tblRegistration(Surname TEXT COLLATE NOCASE, Othernames TEXT COLLATE NOCASE, Address TEXT,", _
  "MobileNo TEXT, CompanyName TEXT, Position TEXT, Nationality TEXT, ArrivalDate TEXT, ArrivalTime TEXT, NoOfNights TEXT, DepartureDate TEXT, DepartureTime TEXT,", _
  "StateArrivingFrom TEXT, StateGoingTo TEXT, Identification TEXT, IDNo TEXT, Sponsor TEXT, PurposeOfVisit TEXT, NoOfGuests TEXT, RoomNo TEXT, RoomRate TEXT,", _
  "RoomType TEXT, BillNo TEXT, StayOver)")
   slExe "Create Index If Not Exists Registrationndx1 ON tblRegistration(BillNo)"
   slExe "Create Index If Not Exists Registrationndx2 ON tblRegistration(Surname)"
   slExe "Create Index If Not Exists Registrationndx3 ON tblRegistration(Othernames)"
 FOR x = -10 TO 10:NEXT
 s$ = "select DepartureDate,DepartureTime,"
 s$+= " case"
 s$+= "   when DepartureDate <= date('now') THEN 'greater'"
 s$+= "   when DepartureDate = date('now') THEN 'less'"
 s$+= "   WHEN DepartureTime > time('12') THEN 'Greater Than'"
 's$+= "  else             'equal'"
 s$+= " from tblRegistration"
 ? s$
  slExe slBuildInsertOrUpdate("tblRoomRates", sRoomNo & $NUL & "Available", "RoomNo, Status", "RoomNo=" & sRoomNo)
        IF Errorcode& = 19 THEN
             MSGBOX "Bill No Already Sent And Is Still Existing In The Registeration History", %MB_TASKMODAL OR %MB_ICONINFORMATION, EXE.NAME$
        slEXE "Delete From tblRegistration WHERE DepartureDate <= date('now') AND DepartureTime >= time('12')"
Rearranged the code into a couple of functions.
Not sure when you want to automatically call a function.
Using a timer, at startup, by a click?
#COMPILE EXE
#DIM ALL
 CreateRecords
 ViewRecords
FUNCTION CreateRecords AS LONG
 LOCAL x AS LONG
 LOCAL s$
 DIM sarray$()
 LOCAL Errorcode&
 sRoomNo = "501"
 'Registration
FUNCTION ViewRecords AS LONG
 LOCAL s,sArray() AS STRING
 s = "select DepartureDate,DepartureTime,"
 s+= " case"
 s+= "  when DepartureDate <= date('now') THEN 'greater'"
 s+= "  when DepartureDate = date('now') THEN 'less'"
 s+= "  WHEN DepartureTime > time('12') THEN 'Greater Than'"
 s+= " end as NewColName"
 s+= " from tblRegistration"
 slselary s,sarray$(),"Q9"
Fredrick Ughimi
Timer would be the best option in the situation. Say 12:05 everyday.
Fredrick Ughimi
>>Would it be better to use task scheduler in case your program isn't running?
I would first like to implement while the application is running, so the program notifies user that a guest has been automatically checked out.
Fredrick Ughimi
#10
FUNCTION PBMAIN () AS LONG
 LOCAL hThread AS LONG
 THREAD CREATE CheckEveryHour(1000 * 60 * 60) TO hThread
 THREAD CLOSE hThread TO hThread
 ? "Done"
THREAD FUNCTION CheckEveryHour(BYVAL Milliseconds AS LONG) AS LONG
 LOCAL x AS LONG
 DO
  IF LEFT$(TIME$,2) = "XX" THEN CALL Something
  SLEEP milliseconds
 LOOP
SUB Something
 BEEP
Fredrick Ughimi
Welcome
Hope you have something working that didn't require a trigger.
Fredrick Ughimi
Hello CJ,
Yes, it is working well.
Fredrick Ughimi
Hello CJ,
Just discovered that my auto delete works fine:
But I could not effectively implement my other two statements, since they are dependent on string variables which are not easy to fill with values due to the nature of the AutoCheckOutGuests function:
Full Function:
Function AutoCheckOutGuests() As Long
    Local Errorcode&
    Local CheckoutAns&
    Local sRoomNo As String
    Local sRecordNo As String
    Local x As Long
    Local s$
    For x = -10 To 100:Next
    s$ = "SELECT RowID as RecordNo,RoomNo as rRoomNo, DepartureDate,DepartureTime,"
    s$+= " case"
    If Errorcode& = 19 Then
        MsgBox "Bill No Already Sent And Is Still Existing In The Registeration History", %MB_TASKMODAL Or %MB_ICONINFORMATION, Exe.Name$
        Exit Function
    If slGetChangeCount = 0 Then
        ? "No Guests is due to leave", %MB_TASKMODAL Or %MB_ICONINFORMATION, Exe.Name$
        Exit Function
    Else
        ? "GuestS moved to the History table and deleted from the current guests table", %MB_TASKMODAL Or %MB_ICONINFORMATION, Exe.Name$
