Debtors List
Started by Fredrick Ughimi, November 05, 2019, 05:19:58 PM
https://sqlite.org/lang_with.html only for me.
This is a first for me, CTE is new have no idea what arsenal is?
I couldn't figure out the relational keys of your 3 tables.
key1
key2
key3
Do payments have to be applied to invoices for some unknown reason?
Is this a running system?
You make it hard for us.
Fredrick Ughimi
Sqlite3 supports CTEs from version 3.8.3 (see https://www.sqlite.org/changes.html). Not sure what SQLite DLL I have installed. I would check later on.
CJ,
The relational key to all three tables is the HospitalNo and in a many to many relationship.
Yes. Since the hospitals allows installment payments. Invoices are not completely paid for by the patient. Invoices carries the total bill, while the Payment Received table carries the amount paid by the patient.
Yes, it is.
Need the relationships and what a detail line or the column heading should be.
Hosital Number  Client Number Invoice Number ....
OK.  I played with cj's code and found the problem.  You cannot use Total() in a WHERE clause.  I reworked the statement and it compiles/works now.
#INCLUDE "sqlitening.inc"
GLOBAL gs AS STRING
FUNCTION PBMAIN () AS LONG
 KILL   "test.db3"
 slOpen ("test.db3", "C")
 'ServicesBill  changed to t1
 slExe "Create Table t1(Date TEXT, BillNo TEXT, HospitalNo TEXT COLLATE NOCASE, Surname1 TEXT, Othernames TEXT, Category TEXT," & _
 "Department TEXT, CodeNo TEXT COLLATE NOCASE, Service TEXT, amount1 REAL, Discount REAL, Status TEXT)"
 'Pharmacy Bill changed to t2
 slExe BUILD$("Create Table t2(RecNo TEXT, SNo TEXT, Date TEXT, InvoiceNo TEXT, HospitalNo TEXT, Surname2 TEXT,", _
 "ProductNo TEXT COLLATE NOCASE, Description TEXT, PatientCategory TEXT, Department TEXT, Quantity REAL, SellingPrice REAL, Discount REAL, Username TEXT)")
 'Payment       changed to t3
 slExe BUILD$("Create Table t3(ReceiptNo INTEGER, BillNo INTEGER, Date TEXT, HospitalNo TEXT, Surname3 TEXT, Othernames TEXT,", _
 "Category TEXT, Stage TEXT, PaymentMode TEXT, CheckNo TEXT, Amount3 REAL, Purpose TEXT, Department TEXT, Cashier TEXT)")
 LOCAL x AS LONG
 FOR x = 1 TO 1
  slexebind "insert into t1 values (?,?,?,?,?,?,?,?,?,?,?,?)",     REPEAT$(12,slbuildbindDat("1","T")) '12
  slexebind "insert into t2 values (?,?,?,?,?,?,?,?,?,?,?,?,?,?)", REPEAT$(14,slbuildbindDat("1","T")) '14
  slexebind "insert into t3 values (?,?,?,?,?,?,?,?,?,?,?,?,?,?)", REPEAT$(14,slbuildbindDat("1","T")) '14
 gs = CHR$( GetRs("select * from t1"),$CR,$CR,GetRs("select * from t2"),$CR,$CR,GetRs("select * from t3")) + $CR
 Bern
FUNCTION Getrs(sql AS STRING) AS STRING
 DIM s() AS STRING
 slSelAry sql,s(),"Q9c"
 FUNCTION = JOIN$(s(),$CR)
SUB Bern
LOCAL s AS STRING
s=  "WITH"
s+="   TempT1(TT1Surname,TT1Total) AS (SELECT Surname1, Amount1 - Discount"
s+="     FROM T1),"
s+="   TempT2(TT2Surname,TT2Total) AS (SELECT Surname2, Quantity * SellingPrice - Discount"
s+="     FROM T2),"
s+="   SumT1( ST1Surname, ST1Total) AS (SELECT TT1Surname, TOTAL( TT1Total)"
s+="     FROM TempT1 GROUP BY TT1Surname),"
s+="   SumT2( ST2Surname, ST2Total) AS (SELECT TT2Surname, TOTAL( TT2Total)"
s+="     FROM TempT2 GROUP BY TT2Surname),"
s+="   SumT3( ST3Surname, ST3Total) AS (SELECT Surname3, TOTAL( Amount3)"
s+="     FROM T3 GROUP BY Surname3)"
s+=" SELECT ST3Surname, ST1Total + ST2Total - ST3Total"
s+="   FROM SumT3"
s+="   INNER JOIN SumT1 ON ST3Surname = ST1Surname"
s+="   INNER JOIN SumT2 ON ST3Surname = ST2Surname"
s+="   WHERE ST1Total + ST2Total > ST3Total"
 DIM sArray() AS STRING
 slselAry s,sArray(),"Q9"
 'slSel s,0,"D"
 ? "Incorrectly attempt Bern statement" + $CR + JOIN$(sArray(),$CR) + STRING$(5,$CR) + "Tables contained:" + $CR + gs
The output doesn't show anything because it's computing zero for TT1Total and TT2Total with the dummy data in this code.  You can remove the WHERE clause from the statement to see it's computing -1 for ST1Total + ST2Total - ST3Total.
This statement flattens all three tables into a single record per Surname/HospitalNo.  The final SELECT is using T3 as the leftmost FROM table, so the output will only list Surname/HospitalNo records if a record exists in (Sum)T3.  If you want results where no record (for Surname/HospitalNo) exists in T3, you would need to adjust the statement to base the results on either SumT1 or SumT2.
I'm not sure how to combine the output to list every Surname/HospitalNo record that exists across all three tables with the db schema as listed.  If you have another table with a master list of Surname/HospitalNo records, you could use that as the base and use LEFT OUTER JOINS on SumT1, SumT2 and SumT3.
 LOCAL sData(),sBind AS STRING, x AS LONG
 KILL   "temp.db3"
 slopen "temp.db3","C"
 slexe  "create table if not exists t1 (acct,amt)"     'charges table1
 slexe  "create table if not exists t2 (acct,amt)"     'charges table2
 slexe  "create table if not exists t3 (acct,amt)"     'payments
 slexe  "drop table if exists TempBalances;create table TempBalances(acct unique,amt)"
 slexe  "insert into t1 values(1,1000),(2,2000),(3,3000)"             'charges t1
 slexe  "insert into t2 values(4,4000)"                               'charges t2
 slexe  "insert into t3 values(4,-2000),(1,-500),(2,-1000),(3,-1500)" 'apply payments
 'combine tables and payments
 slselary " select acct,sum(amt),'t1' from t1 group by acct"  +_     'charges table1
          " union "                                      +_
          " select acct,sum(amt),'t2' from t2 group by acct"  +_     'charges table2
          " union "                                      +_
          " select acct,sum(amt),'t3' from t3 group by acct",sData() 'payments table3
 'update TempBalances() from above sData()
 FOR x = 1 TO UBOUND(sdata,2)
  sBind = slBuildBindDat(sdata(1,x),"T") + slBuildBindDat(sData(2,x),"T")
  slexebind "Insert into TempBalances values(?,?) ON conflict(acct) DO update SET amt=amt+" + sData(2,x),sBind
 ? showit("select * from TempBalances"),,"Balances"
FUNCTION showit(sql AS STRING) AS STRING
 LOCAL sArray() AS STRING
 slselary sql,sArray(),"Q9"
 FUNCTION = JOIN$(sArray(),$CR) + $CR
#35
Both routines are compared in this posting.
Bern,
Nice, learned a lot!!
Bern routine results:
1 payment record must exist to return results for a client
2 credit balances do not display (they weren't asked for)
3 optional, modified to add payments (passed as negative amounts)
The CJ routine could eliminate the creating temp table by reading
through the recordset and handling the debit/credit as they occur.
Made it easier by just creating a temp file with the balances.
Also, for some reason when I dropped the what I thought was unneeded third column in the
union statement t1,t2,t3 the union was not always correct.  Need to look into that.
Leaving "as is" is suggested.
In this example CJ will return 4-records and Bern will return 2-records.
Fredrick, these differences should be considered.
FUNCTION PBMAIN AS LONG
 bern
SUB InsertData
 slexe  "insert into T1 values(1,10),(1,20),(2,10),(4,100)"
 slexe  "insert into T2 values(1,30),(1,40),(2,10)"
 slexe  "insert into T3 values(1,-200),(2,0),(3,-1)"
FUNCTION Bern AS LONG
 LOCAL s AS STRING
 KILL   "temp.db3":IF ERR THEN ? STR$(ERRCLEAR)
 slexe  "create table if not exists T1 (surname1 int,Amount1 int)"
 slexe  "create table if not exists T2 (surname2 int,Amount2 int)"
 slexe  "create table if not exists T3 (surname3 int,Amount3 int)"
 InsertData
 '? ShowIt("select * from t1") + $CR + ShowIt("select * from t2") + $CR + ShowIt("select * from t3")
 s=  "WITH"
 s+="   TempT1(TT1Surname,TT1Total) AS (SELECT Surname1, Amount1"
 s+="     FROM T1),"
 s+="   TempT2(TT2Surname,TT2Total) AS (SELECT Surname2, Amount2"
 s+="     FROM T2),"
 s+=" SELECT ST3Surname as acct, ST1Total + ST2Total + ST3Total as amt"
 s+="   FROM SumT3"
 s+="   WHERE ST1Total + ST2Total <> ST3Total" 'made <> instead of subtract
 '? s,,"Sql"
 ?  ShowIt(s)
 'DIM sArray() AS STRING
 'slselAry s,sArray(),"Q9"
 '? JOIN$(sArray(),$CR),,FUNCNAME$
 slClose
FUNCTION CJ () AS LONG
 KILL   "temp.db3"
 slexe  "create table if not exists t1 (surname1 int,amt int)"     'charges table1
 slexe  "create table if not exists t2 (surname2 int,amt int)"     'charges table2
 slexe  "create table if not exists t3 (surname3 int,amt int)"     'payments
 slexe  "create table TempBalances(acct unique,amt)"
 InsertData
 slselary " select surname1,sum(amt),'t1' from t1 group by surname1"  +_     'charges table1
          " union "                                      +_
          " select surname2,sum(amt),'t2' from t2 group by surname2"  +_     'charges table2
          " union "                                      +_
          " select surname3,sum(amt),'t3' from t3 group by surname3",sData() 'payments table3
 ? showit("select * from TempBalances"),,FUNCNAME$
 slclose
Fredrick Ughimi
#36
Hello CJ & Bern,
Thank you for helping out to find a solution to this.
I think I would along with Bern's version as I have been able to add more fields to it and implement it.
I haven't been able to make CJ's version work for me. I still intend to take another look at it later on.
Thank you guys, I appreciate your efforts and I have learnt a lot from this.
Best regards.
Fredrick Ughimi
Hello Cj,
I tried implementing your version today:
#COMPILE EXE
#DIM ALL
'Both routines are compared in this posting.
'Bern,
'Nice, learned a lot!!
'Bern routine results:
'1 payment record must exist to return results for a client
'2 credit balances do not display (they weren't asked for)
'3 optional, modified to add payments (passed as negative amounts)
'The CJ routine could eliminate the creating temp table by reading
'through the recordset and handling the debit/credit as they occur.
'Made it easier by just creating a temp file with the balances.
'Also, for some reason when I dropped the what I thought was unneeded third column in the
'union statement t1,t2,t3 the union was not always correct.  Need to look into that.
'Leaving "as is" is suggested.
'In this example CJ will return 4-records and Bern will return 2-records.
'Fredrick, these differences should be considered.
   slopen "HospitalProDB.db3","C"
   slexe  "drop table if exists TempBalances;create table TempBalances(HospitalNo unique,Amount)"
 slselary " select HospitalNo,SUM(Amount),'tblBill' from tblBill group by HospitalNo"  +_     'charges table1
          " union "                                      +_
          " select HospitalNo,SUM(SellingPrice * Quantity - Discount) as Amount,'tblCashSales' from tblCashSales group by HospitalNo"  +_     'charges table2
          " union "                                      +_
          " select HospitalNo,SUM(Amount),'tblPayments' from tblPayments group by HospitalNo",sData() 'payments table3
  slexebind "Insert into TempBalances values(?,?) ON conflict(HospitalNo) DO update SET Amount=Amount+" + sData(2,x),sBind
I got incomplete input error.
>>Bern routine results: 1 payment record must exist to return results for a client
I also noticed that all three tables needs to have data for a client to return results for that client.
Quote from: Fredrick Ughimi on December 10, 2019, 10:14:35 AM...
That's because I used INNER JOINs. You can use LEFT OUTER JOINS if you want results from partial matches, but even so, the table referenced after FROM will control the results set, so the results only return for records in that table.
Like I said previously, if you have a fourth table that contains a master list of the Surnames/HopsitalNos, you can use that as the FROM reference and LEFT OUTER JOIN the 3 "SUM" tables from the WITH clause and get a full result set.
Fredrick Ughimi
Hello Bern,
Thank you for your explanations.
Yes, there is a master table I called tblBioData which contains the HospitalNo, Surname, Othernames, etc.
I will follow your instructions and see how it goes. Thanks a lot.
Fredrick Ughimi
Hello CJ,
>>The dummy columns t1,t2,t3 are required to get the correct results.  Please test!
I will test it as soon as I am with my computer. Thanks a lot.
Quote from: Fredrick Ughimi on December 10, 2019, 01:56:25 PM...
Then this should work (adjust table names to match your code):s=  "WITH"
s+="     FROM T1),"
s+="     FROM T2),"
s+="   FROM tblBioData"
s+="   LEFT OUTER JOIN SumT1 ON tblBioData.Surname = ST1Surname"
s+="   LEFT OUTER JOIN SumT2 ON tblBioData.Surname = ST2Surname"
s+="   LEFT OUTER JOIN SumT3 ON tblBioData.Surname = ST3Surname"
Fredrick Ughimi
Hello Bern,
This worked. I am going to test further in the days to come.
Thanks a million.
s=  "WITH"
        s+="   TempT1(TT1HospitalNo,Surname, Othernames,TT1Total) AS (SELECT HospitalNo, Surname, Othernames, Amount - Discount"
        s+="     FROM tblBill),"
        s+="   TempT2(TT2HospitalNo,Name,TT2Total) AS (SELECT tblCashSales.HospitalNo, Name, Quantity * SellingPrice - Discount"
        s+="     FROM tblCashSales),"
        s+="   SumT1( ST1HospitalNo, ST1Total) AS (SELECT TT1HospitalNo, TOTAL( TT1Total)"
        s+="     FROM TempT1 GROUP BY TT1HospitalNo),"
        s+="   SumT2( ST2HospitalNo, ST2Total) AS (SELECT TT2HospitalNo, TOTAL( TT2Total)"
        s+="     FROM TempT2 GROUP BY TT2HospitalNo),"
        s+="   SumT3(ST3HospitalNo, Surname, Othernames, ST3Total) AS (SELECT tblPayments.HospitalNo, Surname, Othernames, TOTAL(Amount)"
        s+="     FROM tblPayments GROUP BY tblPayments.HospitalNo)"
        s+=" SELECT tblBioData.HospitalNo, tblBioData.Surname, tblBioData.Othernames, ST1Total + ST2Total - ST3Total"
        s+="   LEFT OUTER JOIN SumT1 ON tblBioData.HospitalNo = ST1HospitalNo"
        s+="   LEFT OUTER JOIN SumT2 ON tblBioData.HospitalNo = ST2HospitalNo"
        s+="   LEFT OUTER JOIN SumT3 ON tblBioData.HospitalNo = ST3HospitalNo"
Aside: Is it possible to get the:
1 = near ""WITH": syntax error
on one system and not get it on another system? One of my clients had this error, but it worked fine on my system.
Fredrick Ughimi
#43
Hi CJ,
I tried your code directly against my database. It compiled and ran without showing any result.
#COMPILE EXE
#DIM ALL
 LOCAL sData() AS STRING
 slselary " select HospitalNo,SUM(Amount-Discount), 'tblBill' from tblBill group by HospitalNo" +_
          " UNION" +_
          " select HospitalNo,SUM(SellingPrice*Quantity-Discount),'tblCashSales' from tblCashSales group by HospitalNo" +_
          " UNION" +_
          " select HospitalNo,SUM(Amount),  'tblPayments' from tblPayments group by HospitalNo",sData()
 slselary " select HospitalNo,SUM(Amount-Discount), 'tblBill' from tblBill  group by HospitalNo     UNION "  +_
          " select HospitalNo,SUM(SellingPrice * Quantity  - Discount),'tblCashSales' from tblCashSales  group by HospitalNo UNION "  +_
 'without temp table
 LOCAL x,linecounter AS LONG
 DIM hospital(999) AS LONG
 DIM sArray(999)   AS STRING
  hospital(VAL(sdata(1,x))) += VAL(sdata(2,x)) 'combine amounts in column2
 sArray(0) = "Hospital  Amount"  'optional heading
 FOR x = 1 TO UBOUND(hospital)   'hospital 1 to ?
  IF hospital(x) THEN            'if hospital <> 0
   INCR linecounter
   sArray(linecounter) = USING$("#&##.##",x,$TAB,hospital(x)*.01)
  'sArray(linecounter) = FORMAT$(x) + $TAB + USINg$("##.##",hospital(x)*.01)
 REDIM PRESERVE sArray(linecounter)
 ? JOIN$(sArray(),$CR),,"Balances"
I tried again using DDOC this time and discovered I could retrieve the balances.
#COMPILE EXE
#DIM ALL
#INCLUDE "ddoc_p32.inc"
'DDOC
'  Needed Color Constants (Vb compatible)
%vbBlack = &H0&
%vbRed = &HFF&
%vbGreen = &HFF00&
%vbYellow = &HFFFF&
%vbBlue = &HFF0000
%vbMagenta = &HFF00FF
%vbCyan = &HFFFF00
%vbWhite = &HFFFFFF
%vbGrey = &HC0C0C0
%LIGHT_SHADE = &HE0E0E0
   slOpen ("HospitalProDB.db3", "C")
   ReportDebtors
FUNCTION PBDate(sDate AS STRING) AS STRING
     'MM-dd-yyyy to dd-MM-yyyy
     FUNCTION = MID$(sDate,4,2) & "-" & MID$(sDate,1,2) & "-" & MID$(sDate,7,4)
FUNCTION NigeriaDate(sDate AS STRING) AS STRING
     'yyyy-MM-dd  to dd-MM-yyyy
     FUNCTION = MID$(sDate,9,2) & "-" & MID$(sDate,6,2) & "-" & MID$(sDate,1,4)
FUNCTION SQLiteDate(sDate AS STRING) AS STRING
     'From dd-MM-yyyy To yyyy-MM-dd
     FUNCTION = MID$(sDate,7,4) & "-" & MID$(sDate,4,2) & "-" & MID$(sDate,1,2)
FUNCTION ReportDebtors() AS LONG
      LOCAL dbHandle&, LineSpacing!,iHandle%,Row!,TopMargin!,PageSize!,PageNumber&
      LOCAL detailline AS ASCIIZ * 200
      LOCAL SNo AS LONG
      LOCAL lTotalRecords&
      LOCAL dTotalAmount AS DOUBLE
      LOCAL dNetAmount AS DOUBLE
      LOCAL s AS STRING
      LOCAL dTotalDebts, dTotalBill, dTotalPayment AS DOUBLE
      LineSpacing = .2
      TopMargin   = .5
      PAGESIZE    = 10
      ihandle% = dpStartDoc(0,"Mega-Net HospitalPro - Debtors Report","",%DDOC_INCH, %DDOC_PAPER_A4, %DDOC_PORTRAIT, %DDOC_SYSTEM_DEFAULT, %DDOC_BIN_AUTO OR %DDOC_ALLOWSMTP OR %DDOC_ALLOWSAVE OR %DDOC_ZOOMFIT)
      IF ihandle < 1 THEN
           MSGBOX "Could not StartDoc. Error number" + STR$(Ihandle)
           GOTO EndProgram
      dpSetTabs iHandle, "L.5W1 L1.0W1 L2.5W3 L5.5W1 L6.5W1 L7.5W1"
      ROW = PAGESIZE                            'force new heading
    slSEL " select HospitalNo,SUM(Amount-Discount), 'tblBill' from tblBill group by HospitalNo" +_
          " UNION" +_
          " UNION" +_
   slSEL " select HospitalNo,SUM(Amount-Discount), 'tblBill' from tblBill  group by HospitalNo UNION "  +_
      DO WHILE slGetRow()
        IF ROW => PAGESIZE THEN
           IF PageNumber THEN      'If first page don't need a new page
              dpNewPage iHandle%,  %ddoc_PAPER_A4, %DDOC_PORTRAIT, %DDOC_BIN_AUTO
           INCR PageNumber
           LOCAL hjpg AS LONG
             ''hjpg = dpAddGraphic(ihandle%, VD_App.Path & "Logo.jpg")
             IF hjpg THEN
                dpDrawGraphic ihandle%, hjpg,3.5,.2,2,1
           dpText iHandle%, .5,TopMargin,  %DDOC_Left,"Page: "+ STR$(PageNumber)+""
           'dpText iHandle%, .5,TopMargin + .2,  %DDOC_Left,"Total Records: "+ Str$(lTotalRecords&)+""
           dpText iHandle%, 6,TopMargin,  %DDOC_Left,"Date: "+ PBDate(DATE$)+""
           dpText iHandle%, 6,TopMargin +.2,  %DDOC_Left,"Time: "+ TIME$+""
           ROW =TopMargin + LineSpacing * 4
           dpFont ihandle%, %DDOC_FONTNORMAL + %DDOC_FONTBOLD, 12, %vbGreen, "Arial"
           dpText ihandle, 4.25, 1.1, %DDOC_CENTER, "Ameso Hospital" ''& gName
           dpFont ihandle%, %DDOC_FONTNORMAL + %DDOC_FONTBOLD, 12, %vbRed, "Arial"
           dpText IHandle%, 4.25, 1.4, %DDOC_CENTER, "Ogudu, Lagos" ''& gAddress
           dpFont ihandle%, %DDOC_FONTNORMAL + %DDOC_FONTUNDERLINE + %DDOC_FONTBOLD, 12, %vbBlack, "Arial"
           dpText IHandle%, 4.25, 1.7, %DDOC_CENTER, "Debtors Report"
           'dpText IHandle%, 6.25, 2.0, %DDOC_CENTER, "Date Range:  " & sFrom  & " To " & sTo
           'dpText IHandle%, .5, 2.3, %DDOC_Left, "Total Debts: " & Format$(dTotalDebts, "#,.00")
           dpFont ihandle%, %DDOC_FONTNORMAL + %DDOC_FONTUNDERLINE + %DDOC_FONTBOLD, 9, %vbBlack, "Arial"
           dpTabText iHandle%, ROW + 0.9, "SNo" + $TAB + "HospitalNo" + $TAB + "Surname" + $TAB + "Othernames" + $TAB + "Balance"
           dpFont ihandle%, %DDOC_FONTNORMAL, 8, %vbBlack, "San Serif"
           ROW =  ROW + LineSpacing * 2
        INCR SNo
        DetailLine$ =  _
          STR$(SNo) + $TAB + _
          slFN("HospitalNo") + $TAB + _
          slFN("Amount")
          dpTabText iHandle%, ROW + 0.7, DetailLine
          ROW = ROW + LineSpacing                    'increment line counter
      LOOP
      dpEndDoc iHandle%, %DDOC_END_VIEW + %DDOC_END_PRINT
    EndProgram:
Hi Fred, glad the solution worked for you.  :)
Quote from: Fredrick Ughimi on December 11, 2019, 07:17:56 AM...
Positive error message number is SQLite error msg, not SQLitening.  Maybe your client's system has a different (older) version of SQLite .dll installed?
