January 26, 2021, 09:10:38 AM
Would This Work?
Started by Fredrick Ughimi, November 21, 2019, 06:35:12 AM
I will look into it later today.
NordVPN worked great.
I don't like the price of the dedicated server.
I will also add AES256 to SQLitening TCP within a few days.
Fredrick Ughimi
Hi CJ,
That will be great.
Were you able to test without payment. Do they have a trial version? Anyway let's see how Hamachi goes.
November 29, 2019, 12:33:39 PM #17 Last Edit: November 29, 2019, 12:36:49 PM by cj
Paid NordVPN connected with a couple machines using same username/password on one of their servers marked as allowing dedicated connections.  Might break terms of service or not work with more machines.
December 01, 2019, 03:40:23 PM #18 Last Edit: December 01, 2019, 03:42:09 PM by cj
Windows 10 has a built-in VPN server, but I couldn't connect.
Some on the internet say there is a problem introduced in a Windows update.
https://pureinfotech.com/setup-vpn-server-windows-10/
I got Hamachi to connect, but didn't go any further.
I'll go back to encrypting the TCP data being transmit to the server.
Fredrick Ughimi
Hello CJ,
How did you do it?
https://help.logmein.com/pkb_Home?q=share%20a%20port&l=en_US&c=products%3Almihamachi2&atype=FAQ__kav
It looks like you share a folder and use Windows mapping.
I only connected 2 machines and used chat.
I didn't use SQLite with it.
There are links to PDF files at the bottom of their home page.
Many use it so there must be better docs on the net, don't know where.
December 03, 2019, 12:52:55 AM #21 Last Edit: December 03, 2019, 12:55:57 AM by cj
Very interesting read:
https://proprivacy.com/vpn/comparison/nigeria-vpn
I have been successfully using SQLitening over a VPN between machines that share the exact same dedicated VPN server using the same user name and password.  This might be the best way to go if this is allowed.
I paid nothing extra and didn't need any dedicated IP address (other then share same exact server.)
I will finally have time to work on encrypting SQLitening on 12/3.
Fredrick Ughimi
Thanks for the link. Interesting read.
