July 23, 2021, 09:00:29 PM
Join 2D arrays with a column and row delimiter source code example
Started by cj, April 21, 2020, 08:59:39 AM
April 21, 2020, 08:59:39 AM Last Edit: April 21, 2020, 07:51:25 PM by cj Reason: Improved and adding png
Enables a column delimiter and a new row delimiter in new JOIN2$ function.
This makes it easy to display a string from a 2-dimensional array with a $CR  or other characters as a row delimiter.
Improved money macro to automatically display passed column name instead of printf statement.
SQlite "AS" is optional so just appended colname to the money macro.
Don't like leading 0 displaying on money columns so used ltrim to remove it.
Enjoy!
#DIM ALL
MACRO money(colname)= CHR$("ltrim(printf('%.2f',",colname,"*.01),'0')",colname)
#INCLUDE "sqlitening.inc"
FUNCTION PBMAIN () AS LONG
 LOCAL sql,sColDel,sRowDel,rs() AS STRING
 slopen "sample.db3"
 sql = "select manuf,redref,"+ money("PRICE") + " from parts limit 20"
 slselary sql,rs()
 sColDel = "   "
 sRowDel = $CR
 ? JOIN2(rs(),sColDel,sRowDel),,USING$("Rows #_, Cols #",UBOUND(rs,2),UBOUND(rs))
FUNCTION JOIN2(rs() AS STRING,sColumnDelimiter AS STRING,sRowDelimiter AS STRING) AS STRING
 LOCAL sb AS ISTRINGBUILDERA
 sb = CLASS "STRINGBUILDERA"
 'sb.capacity = 1024*1000 'does well without capacity
 LOCAL c              AS LONG
 LOCAL LowCol         AS LONG
 LOCAL HighCol        AS LONG
 LOCAL HighCol_minus1 AS LONG
 LOCAL r              AS LONG
 LOCAL LowRow         AS LONG
 LOCAL HighRow        AS LONG
 LowCol = LBOUND(rs,1)
 HighCol= UBOUND(rs,1)
 HighCol_minus1 = HighCol-1
 LowRow = LBOUND(rs,2)
 HighRow= UBOUND(rs,2)
 FOR r = LowRow TO HighRow
  FOR c= LowCol TO HighCol_minus1
   sb.add  rs(c,r)
   sb.add sColumnDelimiter
  NEXT c
  sb.add rs(c,r)
  sb.add sRowDelimiter
 NEXT r
 FUNCTION = sb.string
