Threaded DDT modeless demo with tabstops using Jose Roca includes
Started by cj, January 28, 2022, 04:56:49 AM
#PBFORMS CREATED V2.01
#COMPILE EXE   'Save as "Modeless.bas"  PBFORMS with Jose Roca includes
#DIM ALL
%UNICODE = 1
#INCLUDE ONCE "Windows.inc"
#INCLUDE ONCE "sqlitening.inc"
#PBFORMS BEGIN INCLUDES
#RESOURCE "modeless.pbr"
#PBFORMS END INCLUDES
GLOBAL ghDlg AS DWORD
#PBFORMS BEGIN CONSTANTS
%IDD_DIALOG1 =  101
%LABEL1      = 1001
%TEXTBOX1    = 2001
%BTN_BUTTON1 = 3001
%TEXTBOX2    = 3002
#PBFORMS END CONSTANTS
#PBFORMS DECLARATIONS
FUNCTION PBMAIN()
 ShowDIALOG1 %HWND_DESKTOP
CALLBACK FUNCTION ShowDIALOG1Proc()
  SELECT CASE AS LONG CB.MSG
    CASE %WM_INITDIALOG
      ghDlg = CB.HNDL
    CASE %WM_NCACTIVATE
      STATIC hWndSaveFocus AS DWORD
      IF ISFALSE CB.WPARAM THEN
        ' Save control focus
        hWndSaveFocus = GetFocus()
      ELSEIF hWndSaveFocus THEN
        ' Restore control focus
        SetFocus(hWndSaveFocus)
        hWndSaveFocus = 0
    CASE %WM_COMMAND
      ' Process control notifications
      SELECT CASE AS LONG CB.CTL
        CASE %BTN_BUTTON1
          IF CB.CTLMSG = %BN_CLICKED OR CB.CTLMSG = 1 THEN
           LOCAL hThread AS LONG
           THREAD CREATE SQLitening(0) TO hThread
           THREAD CLOSE hThread TO hThread
    CASE %WM_DESTROY
      PostQuitMessage 0 'required with modeless Jose Roca message pump
FUNCTION ShowDIALOG1(BYVAL hParent AS DWORD) AS LONG
  LOCAL lRslt AS LONG
  LOCAL hDlg   AS DWORD
  LOCAL hFont1 AS DWORD
  LOCAL hFont2 AS DWORD
  DIALOG NEW hParent, "", 72, 138, 919, 380, %WS_POPUP OR %WS_BORDER OR _
    %WS_DLGFRAME OR %WS_THICKFRAME OR %WS_CAPTION OR %WS_SYSMENU OR _
    %WS_MINIMIZEBOX OR %WS_MAXIMIZEBOX OR %WS_VISIBLE OR %DS_MODALFRAME OR _
    %DS_CENTER OR %DS_3DLOOK OR %DS_NOFAILCREATE OR %DS_SETFONT, _
    %WS_EX_CONTROLPARENT OR %WS_EX_LEFT OR %WS_EX_LTRREADING OR _
    %WS_EX_RIGHTSCROLLBAR, TO hDlg
  CONTROL ADD BUTTON,  hDlg, %BTN_BUTTON1, "Execute", 5, 360, 50, 15
  CONTROL ADD TEXTBOX, hDlg, %TEXTBOX1, "", 5, 25, 910, 265, %WS_CHILD OR _
    %WS_VISIBLE OR %WS_HSCROLL OR %WS_VSCROLL OR %ES_LEFT OR %ES_MULTILINE _
    OR %ES_AUTOHSCROLL OR %ES_AUTOVSCROLL, %WS_EX_CLIENTEDGE OR %WS_EX_LEFT _
    OR %WS_EX_LTRREADING OR %WS_EX_RIGHTSCROLLBAR
  CONTROL ADD LABEL,   hDlg, %LABEL1, "Modeless DDT with Jose Roca includes", _
    387, 5, 230, 20, %WS_CHILD OR %WS_VISIBLE OR %SS_CENTER, %WS_EX_LEFT OR _
    %WS_EX_LTRREADING
  CONTROL ADD TEXTBOX, hDlg, %TEXTBOX2, "select rowid,* from parts", 5, 300, _
    725, 55, %WS_CHILD OR %WS_VISIBLE OR %WS_TABSTOP OR %WS_HSCROLL OR _
    %WS_VSCROLL OR %ES_LEFT OR %ES_MULTILINE OR %ES_AUTOHSCROLL OR _
    %ES_AUTOVSCROLL OR %ES_WANTRETURN, %WS_EX_CLIENTEDGE OR %WS_EX_LEFT OR _
  FONT NEW "MS Sans Serif", 10, 1, %ANSI_CHARSET TO hFont1
  FONT NEW "Courier New", 12, 0, %ANSI_CHARSET TO hFont2
  CONTROL SET FONT hDlg, %LABEL1, hFont1
  CONTROL SET FONT hDlg, %TEXTBOX2, hFont2
#PBFORMS END DIALOG
  DIALOG SHOW MODELESS hDlg, CALL ShowDIALOG1Proc TO lRslt
  LOCAL uMsg AS tagMsg
  WHILE GetMessage(uMsg, %NULL, 0, 0)
    IF IsDialogMessage(hDlg, uMsg) = 0 THEN
      TranslateMessage uMsg
      DispatchMessage uMsg
   WEND '---------- End Jose Roca message pump
  FONT END hFont1
  FONT END hFont2
#PBFORMS END CLEANUP
  FUNCTION = lRslt
THREAD FUNCTION sqlitening(BYVAL x AS LONG) AS LONG
 LOCAL s,sql,sdata2,sdata3,sArray() AS STRING
 CONTROL SET TEXT ghDlg,%TEXTBOX1,s
 slOpen  "sample.db3","C"
 CONTROL GET TEXT ghDlg,%TEXTBOX2 TO sql
 IF sql = "select rowid,* from parts" THEN
  sql =   "select rowid as ROW,MANUF,REDREF,PRODUCT,LANGUAGE,CPU_OS,MEDIA,TYPE,PGROUP,printf('%.2f',price*.01) AS PRICE from parts"
 slSelAry sql,sArray(),"Q9 E2 "
 REDIM lTabStop(1 TO 9) AS LONG
 lTabStop(1) = 22  'manuf
 lTabStop(2) = 160 'redref
 lTabStop(3) = 200 'product
 lTabStop(4) = 440 'language
 lTabStop(5) = 500 'cpu_os
 lTabStop(6) = 540 'media
 lTabstop(7) = 590 'type
 lTabstop(8) = 640 'pgroup
 lTabstop(9) = 820 'price
 CONTROL SEND ghDlg,%TEXTBOX1,%EM_SETTABSTOPS,UBOUND(lTabStop), VARPTR(lTabStop(1))
 s = JOIN$(sArray(),$CRLF)
 LockWindow
 CONTROL SET TEXT ghDlg,%TEXTBOX1,s                    'fill textbox
 REM CONTROL SEND ghDlg,%TEXTBOX1,%WM_VSCROLL,%SB_BOTTOM,0 'scroll to bottom of textbox
 UnlockWindow
'_______________________________________________________________________________________________
FUNCTION rs(sql AS STRING) AS STRING
 LOCAL sArray() AS STRING
 IF slSelAry(sql,sArray(),"Q9 E2 c") THEN
  ? sql + $CR + slGetError,%MB_SYSTEMMODAL OR %MB_ICONERROR,"Recordset"
  FUNCTION=JOIN$(sArray(),$CR)
FUNCTION LockWindow AS LONG
  CONTROL SEND ghDlg, %TEXTBOX1,%WM_SETREDRAW,0,0
FUNCTION UnlockWindow AS LONG
 CONTROL SEND ghDlg,%TEXTBOX1,%WM_SETREDRAW,1,0
