Connect to any server with no program change
Started by cj, July 14, 2022, 11:06:36 AM
Append host port on target line of shortcut to program
Example 1: ip address
c:\sql\bin\program.exe 192.168.0.2 12345
Example 2: computer name
c:\sql\bin\program.exe computername 12345
Example 3: Dynamic ipaddress using freemyip.com
c:\sql\bin\program.exe cool.freemyip.com 12345
#INCLUDE ONCE "sqlitening.inc"  'program.exe
FUNCTION PBMAIN  AS LONG
 IF LEN(COMMAND$) THEN slConnect COMMAND$(1),VAL(COMMAND$(2))
Fredrick Ughimi
Did you get an email notification that I posted this response?
If not, please be sure RECEIVE EMAILS AND ALERTS is choosen on the end of the reply line.
There are several options
Yes, all options are "remote" since slConnect is needed.
The server can be on intranet or internet.
The data is unencrypted to and from the server.
I got an email that you responded.  Did you get an email that I posted this?
Fredrick Ughimi
Hello CJ!
Thank you for your response.
No I did not get an email. I guess it has to do with my settings?
Did you get this one?!
Please click the button on the  end of the reply line and toggle it to Receive Emails and Alerts.
There are probably more things to change and check that you email address is current.
I received a notification Receive Email Notifications and Alerts.  I think something changed for everyone.
